Username Post: 63 SS Correct Rim        (Topic#364852)
ampico-kid
Reg: 07-12-17
04-07-21 04:16 PM - Post#2817676
As I was preparing to grease the front end on my 63 Impala SS, I noticed something that didn't seem quite right. The tie rod end is closer to the wheel on the drivers side than it is on the passenger side. I would think they should both be the same distance. Did some rims space the wheel in or out differently? Here are pics of the two ends in question. Thanks. Bob
ampico-kid
Reg: 07-12-17
04-08-21 06:46 AM - Post#2817690
    In response to ampico-kid
Some additional research revealed that what I'm seeing here are two rims each with a different offset. The offset can be Neutral, Positive, or Negative. Now to determine what I have on the two rear wheels, and decide which offset is best suited to my car.
doubleE
Loc: Eagan MN
Reg: 06-02-03
04-08-21 10:20 AM - Post#2817705
Does the car have stock steel 14" wheels? If so there should be some codes stamped on the wheel to id them. At any rate I would think the offset not to be too critical (give or take an inch) as long as they are the same on each axle. Sure don't want a mis-match like you have now. I would also think the handling would be a bit wacky like pulling to one side.
Eric
Execution time: 0.082 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:03 AM
