Username Post: altenator diode check        (Topic#364851)
sting199
Reg: 12-12-19
04-07-21 10:36 AM - Post#2817657
In trying to check my altenator for occasional dead battery, I got some crazy readings doing a diode check. With my meter on AC, I got about 30 volts, but when I switched leads(pos to neg) the voltage went to 0. Tried the same thing on another battery with the engine off and got the same readings. Is my meter fried? On the AC scale, there shouldn't be any difference in the reading when the leads are switched.
65_Impala
Reg: 12-29-02
04-07-21 01:03 PM - Post#2817667
    In response to sting199
You should not get an AC reading with the engine off.
Try measuring the DC voltage with the headlights on and running at 1500rpm. Should be around 14V. If not, then you need to dig into the alternator further.
beagrizzly
beagrizzly
Loc: south texas
Reg: 08-04-12
04-08-21 07:05 AM - Post#2817692
You can pull the negative cable from the battery. Then put your voltmeter between the post and the cable. It's got to be on D.C.
If you are showing voltage, you have something drawing voltage.
Unhook the alternator lead. check it again. If you don't have any voltage draw, you have bad diodes in the alternator.
Another thing you can do is disconnect the battery. Then let everything cool down. Hook the battery back up and feel the alternator. If it is pulling voltage, it will get warm to the touch.
Just a poor man's troubleshooting process.
You can also take it to a parts house. Most of them can check it for output, and diode function off the engine.
I am lucky enough to have a starter/alternator rebuilder locally that can do all of that, and rebuild it if it needs it.
Griff
1960 Biscayne (the 6T)
2005 Yukon XL
2007 GMC Sierra Classic 8.1
2009 Silverado
2011 Escalade ESV
04-10-21 08:28 AM - Post#2817795
poor mans test.engine off, disconect battery and run a light bulb between the cable and battery. a 1056 bulb should not light up. if it does disconect alternator and try again. diodes fail one ata time normaly. engine running you should not have much ac voltage, sorry i dont know the max number at this time. i always test voltage at the battery terminal and at the alternator terminal. not on the connectors.
04-12-21 12:02 PM - Post#2817913
    In response to bobb
Would a clamp meter work too? Clamp on the positive side. Then disconnect the alternator? If amps drop to 0, it's a bad alternator? "Asking for a friend".
'08 GMC Acadia 3.6L SLE
sting199
Reg: 12-12-19
04-12-21 12:15 PM - Post#2817914
    In response to 65_Impala
Ran that test,,, and the voltage was 14V. Still have a slow battery failure, and I am suspecting faulty diodes.
sting199
Reg: 12-12-19
04-12-21 12:16 PM - Post#2817915
Not sure. sorry
sting199
Reg: 12-12-19
04-12-21 12:19 PM - Post#2817916
    In response to beagrizzly
That would detect a leaking diode, but not a blown diode, would it?
04-13-21 05:42 AM - Post#2817945
Good question. I'm tracking down a parasitic draw. The alternator or starter are my next items to test. I was wondering if using a clamp meter would tell me if one component is bad. A few common parasitic items have been eliminated. Either by unplugging a component, pulling a fuse, or replacement.
65_Impala
Reg: 12-29-02
04-13-21 09:04 AM - Post#2817956
Disconnect the main charging wire and see if the battery still discharges.
Best bet is putting a light bulb or a meter set to read current between the battery negative post and the cable. Disconnect things until the bulb goes off or the meter reads less current. Current should be below about 20mA on most any car with memory storage type electronics in it (radio with clock for example). Otherwise, it should be zero.
Execution time: 0.166 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:12 PM
