Anyone know where I can get a replacement fuse block for my 1963 Bel Air 4 door? I've been looking online for a couple hours and can't seem to locate one
I assume you are talking about the fuse box under the dash and the under dash wiring harness attached to it.
All 63 Chevys have a factory underdash harness that includes the fusebox. The fusebox is "not" sold separately. It would be extremely hard to replace just the fuse box.
You have to buy a original factory style Underdash wiring harness from American Auto Wire. Do not buy the classic update kit from them, buy an original underdash harness
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
62 Imp SS 409 - 5 spd Convertible http://paulstensland.com
I had great support form American Autowire as well and can highly recommend them.
The back side of the fuse block plugs into the wiring block on the other side of the firewall and often the connectors in between often get corroded or lose their spring tension resulting in problems. So it might be a good idea to do both sides.
Thank you everyone!! I went through all of extra parts today and organized. I actually bought all my wiring from American Auto Wiring when I swapped it before! I'll definitely be going back to them if I need to replace anything. They were very helpful
I am doing a full check on the wiring tomorrow to see where the failure is. I'll let you guys know what I find out
