Username Post: lower splash aprons        (Topic#364836)
samsonized1
samsonized1
Reg: 04-12-20
04-06-21 07:26 AM - Post#2817583
cannot figure out how lower splash aprons at the back of the front fenders attach. does anyone have a pix of them installed
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
04-06-21 09:23 AM - Post#2817589
    In response to samsonized1
The red indicates a "U" shaped bracket that attaches to the frame and the underside of the vertical panel. The blue indicates the location of the triangular shaped panel which attaches to the body, the vertical panel and the bracket.
The second photo shows all baffling in place including the "U" shaped bracket and the angled deflector that spans the distance between the fender and the frame just behind the upright and triangular baffles.
Attachment: Inner_fender_baffles.jpeg (3.16 MB) 1 View(s)
Attachment: Splash_Baffle_Between_Fender_and_Frame.jpg (343.33 KB) 6 View(s)
1951 Fleetline Preservation
dsacton
dsacton
Loc: Boulder, CO
Reg: 11-01-11
04-06-21 09:39 AM - Post#2817590
Here are two more photos.
Attachment: Picture1.jpg (56.19 KB) 9 View(s)
Scott Acton
1954 Chevy Bel Air 2-door
http://www.my54chevy.com
RAM_51
RAM_51
Reg: 12-28-02
04-06-21 09:50 AM - Post#2817591
Keep in mind that the '53-'54 long upright panels do have the angled bend in them, whereas the '49-'52 upright panels do not.
mark50
Loc: SF, CA
Reg: 05-10-04
04-07-21 06:25 PM - Post#2817682
    In response to RAM_51
Question for you guys that have removed and reinstalled fenders and inner fenders: is it easier to attach the two together, then install onto the car? Or is better to put the inner fender on the car first, then attach the fender?
eplantage
Loc: Southern MN
Reg: 03-15-04
04-08-21 03:55 AM - Post#2817688
    In response to mark50
It was easier for me to put the inner fenders on first then the outside fenders. Looking at photos of the assembly lines the entire front clip was assembled together and then installed on the chassis. I didn't tighten anything until it was all in place for adjustments.
Age: 67 at the moment
1950 Chevrolet Sedan Delivery
2002 Heritage Springer FLSTSI
1930 Model A Standard Coupe
RAM_51
RAM_51
Reg: 12-28-02
04-08-21 09:08 AM - Post#2817701
Six of one, a half dozen of another. During assembly at the factory, a jig was used to assemble the front clip. If you use the car itself as the jig, there is nothing that you cannot access for assembly or bolt tightening etc., although the fender side spear and "DeLuxe" name plate should be attached to the fender before "hanging" the fenders.
If you are working alone, I would assemble things piece by piece to the car. If you assemble the front clip in its entirety to be put on as a unit, it will be best that you have help and that the doors are protected when the clip is set on the car.
The photo below is a 1949 front clip assembly area at the Flint, Michigan Fisher Plant with whom I believe is an inspector checking over the work on a 1949 front clip before installation:
mark50
Loc: SF, CA
Reg: 05-10-04
04-08-21 09:13 AM - Post#2817702
Thanks to you both! Great reference that helps a lot. Maybe having an accessory cigarette during reassembly makes it go smoother too? :wink :
RAM_51
RAM_51
Reg: 12-28-02
04-08-21 09:39 AM - Post#2817703
It looks like the two responsible for assembly of the clip in the foreground take a break and chat with others, while the inspector does his thing.
dsacton
dsacton
Loc: Boulder, CO
Reg: 11-01-11
04-08-21 02:04 PM - Post#2817715
Don't forget the spacers under the radiator support. Nothing will fit (doors, hood) if you leave those out.
Scott Acton
mark50
Loc: SF, CA
Reg: 05-10-04
04-08-21 04:05 PM - Post#2817725
    In response to dsacton
Thanks, yes I have the radiator spacers in place. It all started out innocently enough, trying to fix the sagging drivers side door— and before you know it half the front end is apart and getting worked over. Rust repair, anti squeak seals, new paint and wiring etc. I even worked out the factory sheet metal wrinkles from the inner fender. Fortunately I kept the passengers side together for reference! Thanks again.
dsacton
dsacton
Loc: Boulder, CO
Reg: 11-01-11
04-09-21 12:41 PM - Post#2817764
Same thing happened to me! I do hope you did some suspension work while you had it apart...
I found that the culprit for my doors was the hinges. You can replace those pins in the hinges.
Scott Acton
Edited by dsacton on 04-09-21 12:43 PM. Reason for edit: No reason given.
Execution time: 0.108 seconds.   Total Queries: 19   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:26 AM
