Username Post: 9 in brake booster        (Topic#364833)
rick1965
Loc: joliet ill
Reg: 12-07-16
04-05-21 05:50 PM - Post#2817540
so purchased a new delco style 9 in. power brake booster for my 65 ss , old one was tired and leaking , so the problem im having is mounting the new one to the firewall , the mount bolts are 3 1/2 center to center on the top and 3 3/4 center to center on the bottom , the new booster is 3 1/2 top and bottom center to center and will not go through the firewall , is this how they are made now? anyone experience this? i emailed classics tech support and will see what they say , wrong part maybe? sure dont want to drill out the firewall ugh....
chopr1
chopr1
Reg: 01-11-19
04-05-21 09:52 PM - Post#2817556
    In response to rick1965
Bottom holes simply elongate hole to allow the bottom bolts to go in. Doesn't take much on each side. I used a air Dremel, some say to file but the metal is hard. I got my 9" from another source but have the same dimensions as yours.
Execution time: 0.089 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:59 AM
