Username Post: Runs rough when accelerating        (Topic#364831)
Liberty Valance
Liberty Valance
Loc: Euless,Texas
Reg: 07-21-14
04-05-21 06:09 AM - Post#2817510
I have an upgraded dist from points to HEI 5 years ago.
Engine started running rough this last week when accelerating. Runs normal in Park or Neutral. Runs rough in gear sitting still also. Replaced plugs and the in-carb fuel filter today and no difference. Truck died on the street last weekend and I found a vaccuum hose had split on the end and fell off. Trying to restart I flooded carb and could not start for a while. This flooding may have caused an issue in the carb. The last rebuild was July 2017. Thinking I may need to rebuild again, not sure.
I have rechecked all vacuum lines, plug wires and all are good. Pulled dist cap and nothing bad found. Checked fuel lines and cannot find anything I can tell that is causing this. Would a bad ignition module cause this or possibly coil? I have had a no start due to the module before.
1974 Cheyenne 10 LWB STOCK 350 W/HEI /TH350 /AC/ 4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
04-05-21 09:47 AM - Post#2817521
    In response to Liberty Valance
How old is the fuel pump? Do you have a timing gun? You can connect it to check for timing advance. Is the choke opening all they way?
'08 GMC Acadia 3.6L SLE
Liberty Valance
Liberty Valance
Loc: Euless,Texas
Reg: 07-21-14
04-05-21 10:28 AM - Post#2817523
Fuel pump is about 2 years old, it is an AC delco. Had auto store brand that did not last long so got the higher priced AC Delco. Haven't checked timing yet, but did disconnect vacuum for dist and engine acted just as usual. Will check timing. Truck does idle in Park normal even when revving there is no rough running I can tell.
Mopar by Birth
Chevy by Choice
04-06-21 08:06 AM - Post#2817586
i would start from sqyare 1 with a tune up and compresion test
sawyer
sawyer
Loc: Long Beach, CA
Reg: 10-23-15
04-07-21 10:51 AM - Post#2817658
Which model Q-jet do you run? I had similar issue at high rpm, was the pump in my E4ME which was a dual designed for off-road use vs the standard single pump.
Long Beach, CA
'85 350 K5
'89 318 Dodge W150
Liberty Valance
Liberty Valance
Loc: Euless,Texas
Reg: 07-21-14
04-10-21 03:34 PM - Post#2817824
    In response to sawyer
I have the R4-4MV carb.
UPDATE
I performed all the troubleshooting I could do with only having a carport and limited tools. Finally decided to take it to my tech and said my cam had finally worn down that is causing the rough running. He had discovered the #8 cam lobe was worn a few years ago when replacing the valve stem seals. It was worn and only raising rocker arm a little. He is in the process replacing cam. He is going to put in an Edelbrock Performer cam. He said it is the beefiest he could install without any other upgrades which is more than the stock one. Should be finished by next Friday.
Mopar by Birth
Chevy by Choice
04-12-21 03:22 AM - Post#2817892
Nice! Save the cam! Can you post a picture of it? Any plans to upgrade the intake? With everything off, a nice dual plane intake would help it breath better.
Liberty Valance
Liberty Valance
Loc: Euless,Texas
Reg: 07-21-14
04-12-21 01:56 PM - Post#2817918
Don't have a pic now but did see it. That one lobe was almost completely round. There were others worn, of course, but not as bad. I think I will keep my original intake.
This is the cam going in.
https://www.summitracing.com/parts/edl-2102
I don't think it came from summit but found this first in my search. Maybe will have a little more kick, or a tap at least....LOL
Mopar by Birth
Chevy by Choice
1983G20Van
Loc: Bedford, Texas, USA
Reg: 11-13-02
04-16-21 11:52 AM - Post#2818171
That cam while not huge will want some tweaks to the Q-Jet to run best. If it has not had the throttle shafts brushed they should be. The idle down tubes enlarged, idle channel restrictions enlarged, idle mixture screw openings enlarged, the idle air bypass ports either drilled or enlarged and also the pull over enrichment system tweaked. The accelerator pump plunger length should be shortened to about 2.50" overall and a stiffer spring used on the top side of it. Accelerator pump shot holes also increased slightly in size. Also like to add little divits to the leading edge of the secondary air doors that align with the secondary poe ports. That cam will enjoy the primaries jetted up 2-4 jet sizes as well. Would also step up to atleast a DR if not DA secondary rod. Set the airdoor tension to about 3/4 turn with a new spring and new hanger cam. Finally I would run a 0.149" seat for the needle and seat to give the thing enough fuel. Even with smog era heads that cam should approach 300 hp.
This was the first test start and run of the Q-Jet I just built on an 11:1 aluminum head 383 with a 218/228 @ 0.050 roller cam on a 108 LSA. Had not even done any adjustments yet other than what I did on the bench. Put it on, set the fast idle cam to the highest step with a bump of the throttle, spun it over and as soon as fuel hit the float bowl it fired up and ran. Idle was pretty smooth around 650 rpm once the fast idle pulled off. No load on it, but the thing is responsive as can be. I had the engine running on the Edelbrock 1406 I also rebuilt and recalibrated about 5 minutes before I shot this clip.
https://youtu.be/l7XDuEvqFR4
Edited by 1983G20Van on 04-16-21 11:57 AM. Reason for edit: No reason given.
Execution time: 0.082 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:45 AM
