Username Post: Paper air filter '49 Chev        (Topic#364827)
matt49
Reg: 05-26-05
04-04-21 09:16 PM - Post#2817491
Can anybody give me a part no. for a paper air filter element to replace the mesh element in my '49 Chev? The measurements look like 8" O.D., 6" I.D. and 1 1/2" tall. Anything close?
TY in advance!
Matt
eplantage
Loc: Southern MN
Reg: 03-15-04
04-05-21 05:21 AM - Post#2817508
    In response to matt49
Sounds like a standard 8" lawnmower filter by dimension. Oregon brand.
Age: 67 at the moment
1950 Chevrolet Sedan Delivery
2002 Heritage Springer FLSTSI
1930 Model A Standard Coupe
04-05-21 08:21 AM - Post#2817517
    In response to eplantage
Is anything wrong with the original oil bath air filter? I love mine.
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
04-05-21 09:44 AM - Post#2817520
I could be wrong, but I believe, with the measurements Matt has provided, has the Standard Dry Element air filter that has the oiled metal gauze element and is trying to find a paper replacement for the gauze.
Attachment: Standard_Dry_Element_Air_Filter.jpg (146.82 KB) 1 View(s)
1951 Fleetline Preservation
04-05-21 01:24 PM - Post#2817527
    In response to RAM_51
Gotcha. Thanks Ram.
matt49
Reg: 05-26-05
04-05-21 05:32 PM - Post#2817538
TY for the replies, folks. Yes, I'm trying to find a replacement for the gauze-mesh element, which doesn't look very efficient to me.
Matt
2D51STYDLX
2D51STYDLX
Loc: So. Prairie Washington
Reg: 03-03-11
04-05-21 08:39 PM - Post#2817549
I took the guts out of my 51and put in a Wix # 42193.
Roger
1951 2 door Deluxe Bone stock, well not quite, bucket seats.
Broken hearts and dirty windows
Make life difficult to see
Thats why last night and this morning
Always look the same to me
John Prine
bobt
Loc: colonial heights va
Reg: 06-28-14
04-06-21 03:04 AM - Post#2817561
    In response to 2D51STYDLX
OK.Some people confuse the mesh filter with an oil bath filter. My 1951 has the MESH filter. To convert it to a paper filter is easy if you have just a little mechanical ability. The paper element will be FRAM CA-140 PL. This filter element fits perfect but stands a little taller. OK, Here's the tricky part. Saw off the stud that holds the top domed cover on the assembly and braze or solder an extended stud in its place. I used an inverted 1/4 inch bolt (1/4 x 20) DON'T MAKE IT TOO LONG OR IT WILL HIT THE HOOD WHEN YOU CLOSE IT. After I did mine, I put a small clump of clay on top of the extended stud to see that I had enough clearance. I am VERY happy with the results. bobt
Execution time: 0.108 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:23 AM
