Username Post: Engine dies randomly        (Topic#364764)
kenh
Reg: 09-12-20
03-30-21 10:12 AM - Post#2817139
I have a 1990, K1500, 5.7 TBI. 224,000 miles.
Very randomly the engine will just shut off, like you turn the key off.
It is totally random. Yesterday I started the engine after a short time in a store. Idled to the end of the row I was parked in, and it died. I have been driving down the road at 60 MPH and it will die. Coasting to a stop sign from 60 and it has died. It might happen twice in a day or go two months without incident.
I've changed the ignition module after the first time but that module was dead. Second time I changed the module again but the "old" module tested OK.
I've checked for loose connections but found none. The wires to the coil seem a bit on the tight side like something is not positioned correctly but I don't think that is an issue???
I bought the truck about a year ago and this is the only ongoing issue I can't solve.
Any ideas will be much appreciated. Thank you!!
Ken
CowboyTrukr
"1`th Year" Silver Supporting Member
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
03-30-21 05:12 PM - Post#2817154
    In response to kenh
Ken, get your hands on a TBI fuel pressure test kit. The big chain stores usually have them available for rent.
Tie it into the fuel line after the filter. Let us know what you find.
Greg
‘01 Silverado 2500HD 8.1/Allison 1000 Xcab/LB
'00 Explorer XLT 4.0 SOHC V6 Auto
'95 K1500 Z71 EC Short Step 5.7L+0.040/NV3500 SOLD
YOUNG57
Loc: Tennessee
Reg: 12-06-10
03-31-21 07:33 AM - Post#2817194
    In response to kenh
Did you put heat conducting grease under your ignition module (between it and the housing)? They are heat sensitive.
kenh
Reg: 09-12-20
04-01-21 08:35 AM - Post#2817271
    In response to YOUNG57
Young, I did grease the ICM with the provided grease. Yes I know they are heat sensitive. Also made sure the mating surfaces were nice and clean before adding the grease.
Cowyboy, It seems weird that fuel pressure would be the cause of this problem but I can sure check it. Maybe I should put a gauge in the cab to monitor the pressure???
Could I have a funky ignition switch? NOT the tumbler, but the switch itself?
Thanks!
Ken
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
04-02-21 08:17 AM - Post#2817334
    In response to kenh
Fuel pumps are strange. I had a brand new Bosch pump go bad on me within 3 days of installing. Going down the highway at 65 and it just died.
I replaced it with a Delphi HP10000 and never had another problem.
It’s worth checking so you know. The TBI pump pressure is a lot more forgiving than on the Vortec engines.
Greg
Senior Moderator
04-02-21 08:37 AM - Post#2817337
    In response to CowboyTrukr
100% agreed. I've personally experienced a TBI pump that was somewhat intermittent before it gave up completely. Checking spark and fuel pressure at the time of failure is what will help track down the cause. Problem is, without the special fitting installed so that you can check pressure (see the FAQ post at top of the forum) it's tricky to be "ready to go" to check pressure when the truck stalls out. You can check spark quickly and rule that out. With the pressure kit fitting installed in a permanent or semi-permanent position, you can check fuel pressure quickly, too. I drove around for a few days with the gauge in my door panel pocket ready to slap it on.
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
04-02-21 09:38 AM - Post#2817342
    In response to someotherguy
If you want permanent monitoring, you can do this. I bought an adapter and tied it in at the throttle body. You have to unhook the fuel line clamp that’s tied to the upper transmission bolt so you can pull the fuel line back enough without kinking it.
If anybody wants to see the live video feed of that Bosch failing, feel free to PM me your email and I’ll send it.
I just don’t have a YouTube account set up to link it here.
Attachment: 90A37EF5-D2C8-40C8-B9DC-9FF73F48A8CB.jpeg (1.89 MB) 3 View(s)
Greg
kenh
Reg: 09-12-20
04-03-21 02:57 PM - Post#2817401
What is is weird is it will restart while coasting. Like as soon as it dies it will immediately restart. Maybe some funky wiring, bad ground?????
If the damn thing would just die and stay dead then it could be fixed! :laugh :
Ken
lt1zr28
Reg: 04-02-21
04-03-21 06:58 PM - Post#2817405
    In response to kenh
I had a similar thing happen. This may not be the fix but here we go. My 88 would die in drive or reverse unless I would keep my foot on the gas. There is an oil pressure sending unit at the back of the intake behind the distributor that was weak.It sends a signal to the computer to engage the fuel pump. Be careful if you try to replace it as the brass 90 is not very strong.
kenh
Reg: 09-12-20
04-04-21 06:18 PM - Post#2817482
    In response to lt1zr28
Already been replaced. Oil pressure is OK verified by a regular gauge. A little low but not much.
Ken
lt1zr28
Reg: 04-02-21
04-04-21 08:10 PM - Post#2817489
    In response to kenh
Did you check to see if you have any codes ?
Maxbigblock
Site Ambassador -
Loc: Stuart, Florida
Reg: 12-16-01
04-06-21 03:37 AM - Post#2817564
    In response to kenh
Ken
I've had the same problem with my 1988 pickup. It dies and then will restart and run great. It usually goes 2 to 3 years or more between incidents.
Max
I'm originally from the ONCE great city of Flint, Michigan. The birthplace of General Motors, where A C Spark Plug was formed and headquartered, where the first Corvettes were hand built, and where my 1955 Chevy was made.
BigDogSS
BigDogSS
Loc: SoCal
Reg: 12-21-01
04-07-21 06:01 PM - Post#2817680
    In response to kenh
I say find and clean all of the grounds and make sure they have a great connection.
    1967 Chevrolet Impala SS convertible 327 - Ermine White C1 - VCCA Senior Award
    1967 Chevrolet Impala SS Sport Coupe 396 - Marina Blue FF - personal "barn-find" lol
Execution time: 0.086 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:42 AM
