Username Post: Radiator hoses        (Topic#364693)
sz0k30
sz0k30
Loc: Oakland Co., Michigan
Reg: 10-12-08
03-24-21 12:59 PM - Post#2816716
Got a 75 Monte with a 454. Looking for part numbers for 73-75 "factory fitting" not the B.S. lousy fitting "Replacement" hoses that seem to be all that auto parts stores have.
Site Ambassador
03-24-21 07:26 PM - Post#2816733
    In response to sz0k30
It looks like Rockauto carries some nice pre-formed ones as well as the crappier ribbed universal type.
1957 Cameo Carrier
sz0k30
sz0k30
Reg: 10-12-08
05-22-21 05:46 AM - Post#2820379
    In response to wagonman100
Everybody carries nice preformed hoses. Except none of them are correct.
Site Ambassador
05-27-21 06:36 PM - Post#2820664
The only other thing I can suggest is to bend a piece of wire to the shape you need (I used a coat hanger for my El Camino with a TPI conversion and aftermarket radiator), measure the inside diameters you will need and see if the parts store will let you check out their hoses and see if they have anything that meets your needs. I found the hoses for my El Camino pretty quickly. One hose needed to be trimmed a bit shorter, but they worked. I don’t remember what they upper hose was for, but the lower was for a Ford diesel truck.
1957 Cameo Carrier
sz0k30
sz0k30
Reg: 10-12-08
05-31-21 12:21 PM - Post#2820908
I know how to look for rad hoses. Like I said, there are hoses that are maybe "close enough", and hoses that can be made to work. This rant is about the fact that auto parts stores can't and don't want to stock every hose ever made. Hose manufacturers want to minimize the number of hoses they make. So for our old cars instead of making six that will fit six different applications, like the originals, they make one to "kind of fit" six applications.
2nd gen Montes had a shelf built into the shroud to support the long hose. None of the hoses I found & tried are made to sit on this shelf. And this pisses me off!
Site Ambassador
06-01-21 05:28 PM - Post#2820988
Sorry, just trying to help deal with the situation. I can appreciate your frustration with it. I guess you have to look at it from their end too. How many hoses for mid 70s big block Monte Carlos are they going to sell? There should be an option to order them and they be made to order. It would be a bit more expensive, but feasible.
1957 Cameo Carrier
Mercedes
Reg: 07-09-18
08-29-21 10:05 AM - Post#2826213
Someone may have changed the radiator years ago making what is the correct hose not fit.
The basic mounting for either big block or small block is very similar.
If nothing comes close, then I would take another look at your ride.
Execution time: 0.109 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:50 PM
