norm55
Loc: fl
Reg: 05-25-13
03-15-21 10:05 AM - Post#2816203
i have a 55 belair. it has a chevy 305 ci with an edelbrock 500 cfm my set up is 86 main jets 67x55 metering rod and purple spring. 19" manifold vac.
#6 on calibration ref chart. i was wondering if i went to #17 on the chart. which is 83 main jet 57x49 metering rods should that give me better mileage it shows a little richer on cruise but jets are smaller
any info on this would be helpful
thanks norm
Member #409
03-15-21 01:08 PM - Post#2816219
In response to norm55
Only if you're too lean now.
norm55
Loc: fl
Reg: 05-25-13
03-15-21 01:35 PM - Post#2816221
In response to Rick_L
rick l. so if i am too lean i am using more fuel than if i was running richer? i don't think i am too lean now .
Member #409
03-15-21 02:38 PM - Post#2816223
So you don't trust the chart? Why did you mention it then?
norm55
Loc: fl
Reg: 05-25-13
03-15-21 03:55 PM - Post#2816229
i trust the set up .just not too much experience with it .looking for most economical set up . i get about 10 mpg on short hops around town
niftyfive
Loc: Colorado
Reg: 02-07-05
03-18-21 06:45 AM - Post#2816352
Short hops? Not enough time too get to full op. temp? Im running same carb (elec choke 1403). Watch your tailpipe and plugs to fine tune the carb. I found the chart to be spot on except my elevation is 7000’
