Username Post: 1964 impala steering wheel nut        (Topic#364495)
basstracker
Reg: 11-09-18
03-01-21 07:21 PM - Post#2815381
hello everyone, can someone tell me the size of the nut that holds the steering wheel on? my shaft is kind of messed up and i might haft to try to retread it. has anyone done that. thanks
Spas602
Spas602
Loc: Phoenix, AZ
Reg: 08-30-17
03-03-21 06:08 AM - Post#2815465
    In response to basstracker
The nut size is 3/4 with washer. My dad said to file the edges carefully then use a retreader. Rock the retreader back and forth to get a good starting thread. That’s what he did on a 63 ss column.
Or you can use a different shaft if needed. Hope this helps.
Attachment: 86957F51-196F-4814-B706-1AC266BC8D10.jpeg (2.95 MB) 6 View(s)
My CT Build Page:
https://bit.ly/3dAB7Wx
pvs409
pvs409
Loc: Sergeant Bluff, Iowa
Reg: 01-10-05
03-03-21 06:25 AM - Post#2815467
    In response to Spas602
the shaft is fine thread.....
Paul
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
http://paulstensland.com
55Brodie
Loc: Little River, SC
Reg: 12-26-15
03-03-21 07:24 AM - Post#2815477
https://www.classicindustries.com/product/g6532.ht...
junky
Loc: Northeast CT
Reg: 06-27-10
03-04-21 06:18 AM - Post#2815536
Damaged threads are not the end of the shafts useful life. Rethread it with a Metric die that is slightly smaller than the original threads, and use a new nut and washer, if rethreading with the proper size die, a new nut doesn't resolve your problem. Don't overtighten it, since the wheel is held on by the splined section of the shaft, the nut is there to keep you from pulling the wheel up.
The picture shows that at some point, someone used a steel hammer to remove the steering wheel. You can file the top of the shaft flat, and once you establish the steering straight ahead, you can mark the shaft with a magic marker, until you are satisfied with the alignment, and then permanently mark it with a sharp chisel and one blow of the hammer. Hammering on a steering shaft isn't the way to remove the steering wheel, but if you must, then use a plastic dead blow hammer.
Execution time: 0.115 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:46 AM
