Username Post: Carb base plate rebuild        (Topic#364464)
rls8836
Loc: North La.
Reg: 01-30-02
02-26-21 04:20 PM - Post#2815150
Was watching a video on the Rochester base plate rebuild and was looking at Oreilly’s and advance auto and speedway motors for a throttle bushing reamer with the new bushings. Haven’t found them what terminology should I use in my searches thank
Joeyd59
Gold Supporting Member
Joeyd59
Loc: New Jersey
Reg: 02-11-12
02-27-21 10:01 AM - Post#2815206
    In response to rls8836
Are you referring to the Q jet carburetor or any aluminum base plate or throttle body?
Edited by Joeyd59 on 02-27-21 10:26 AM. Reason for edit: No reason given.
56sedandelivery
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
02-27-21 10:58 AM - Post#2815213
FYI, E-Bay lists carburetor bushing repair kits for various sized shafts. They come with the reamer and several bushings for roughly $40.00.
I am Butch/56sedanhdelivery.
rls8836
Loc: North La.
Reg: 01-30-02
02-27-21 07:20 PM - Post#2815238
    In response to Joeyd59
Joeyd59 I’m referring to a 2 barrell carburetor off of a 74 Chevy 350
rls8836
Loc: North La.
Reg: 01-30-02
02-27-21 07:21 PM - Post#2815239
56sedandelivery thanks that what I was looking for
carbking
carbking
Loc: Missouri
Reg: 06-14-03
03-23-21 11:47 AM - Post#2816673
In the for what its worth category:
If you have a good milling machine (not a drill press, CERTAINLY not a hand drill) go for it.
Otherwise, if you only plan to do one carburetor base, would highly suggest take the throttle body apart, and take it to a local machine shop to have the bushing procedure done.
Or, if you plan to work on lot of carbs, watch the machinery auctions for a good milling machine.
No, I no longer do them, please do not send it to me.
Jon.
Good carburetion is fuelish hot air!
The most expensive carburetor you will ever buy.....is the incorrect one you attempt to modify!
If you truly believe "one size fits all", trying walking a mile in your spouse's shoes!
rls8836
Loc: North La.
Reg: 01-30-02
03-24-21 07:28 PM - Post#2816734
    In response to carbking
Thanks carbking
Execution time: 0.094 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:43 AM
