Username Post: 1938 prop rod bracket        (Topic#364453)
blue_63
blue_63
Loc: N Dakota
Reg: 11-06-01
02-25-21 01:03 PM - Post#2815073
While replacing the rotted firewall in my 38, I had to take off the brackets that the rod would sit on when the hood is open. I took measurements in order to put them on the new firewall, but have since lost them. I am hoping that some one could help me out by giving me some measurements, or even a photo. Thanks in advance.
Greg
Edited by blue_63 on 02-26-21 08:05 AM. Reason for edit: No reason given.
SSK38
SSK38
Loc: Regina SK
Reg: 02-01-11
02-25-21 06:12 PM - Post#2815096
    In response to blue_63
I'm an hour away from mine, but they look like this...
https://iandireproduction .com/products/hp267-f
blue_63
blue_63
Loc: N Dakota
Reg: 11-06-01
02-26-21 08:07 AM - Post#2815124
    In response to SSK38
I edited the post, I need to know where to put the old brackets onto the new firewall. Sorry about any confusion.
SSK38
SSK38
Loc: Regina SK
Reg: 02-01-11
02-26-21 10:05 AM - Post#2815132
I found an old picture. (Obviously, one bracket is loose.) Like I said before, I'm an hour away from the car, so I can't give you measurements. I hope this helps!
blue_63
blue_63
Loc: N Dakota
Reg: 11-06-01
02-28-21 11:09 AM - Post#2815272
Thank you very much for the picture. It will help me greatly. I can also use the radiator support rod holes for reference. Just what I needed!
By the looks of your picture, you car is in fairly decent shape.
Edited by blue_63 on 02-28-21 11:16 AM. Reason for edit: No reason given.
Rockit53
Rockit53
Loc: Bolingbrook, IL
Reg: 06-15-06
03-01-21 03:05 PM - Post#2815362
I did a quick measurement on my '38 and it's about 8" center to center from the cowl support rod holes to the hood prop rod brackets. I hope that helps!
blue_63
blue_63
Loc: N Dakota
Reg: 11-06-01
03-13-21 12:35 PM - Post#2816081
    In response to Rockit53
That does help. Thank you for your help.
Greg
Execution time: 0.124 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:03 PM
