dtreat
Loc: Virginia
Reg: 10-25-20
02-22-21 03:54 PM - Post#2814899
Finally got the brake system replaced on my '50 Fleetline, was so happy to have one step done towards getting this thing running. Following the manual, I repacked the bearings and torqued the hubs to 33lbs on both front wheels. Driver side wheel won't turn, right side does. Drum will turn before torqueing, so I am sure it isn't the brakes. Bearings and Races look good. Bearings turn by hand when not in the hub. Both sides put together the same. Any thoughts? What could I have done wrong? Would it be OK to not tighten so tight?
drtyler
Loc: Georgia
Reg: 05-06-10
02-22-21 04:08 PM - Post#2814901
In response to dtreat
Ball bearings or tapered roller bearings?
tommy49
Loc: Kaleva, Michigan
Reg: 09-28-12
02-22-21 04:47 PM - Post#2814905
http://chevy.oldcarmanualproject.com/shop/1949_53/...
dtreat
Loc: Virginia
Reg: 10-25-20
02-22-21 05:24 PM - Post#2814907
In response to drtyler
ball bearings.
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
02-22-21 08:36 PM - Post#2814915
The nut is supposed to be backed off a certain distance after torquing...according to shop manual.
1951 Fleetline Preservation
'50 Styleline DeLuxe 4 DOOR SEDAN (Mist Green) |
bobt
Loc: colonial heights va
Reg: 06-28-14
02-23-21 03:16 AM - Post#2814922
In response to RAM_51
Are you using a cheap Chinese torque wrench? If yes, borrow a different one.
beagrizzly
Loc: south texas
Reg: 08-04-12
02-23-21 06:34 AM - Post#2814934
According to the shop manual linked above, the proper torque, then back off 1/4 turn.
If you leave it too tight, it will grind your bearings to nothing pretty quick. Too loose, same result. Ball bearings aren't very forgiving.
My dad always taught me to tighten the nut until it wouldn't turn. This seats new races in the bore, and sets bearings on the shaft. Then back it off until it turns. This usually happened to be about 1/4 turn. Funny how the shop manual seems to be right on these things. lol.
Griff
1960 Biscayne (the 6T)
2005 Yukon XL
2007 GMC Sierra Classic 8.1
2009 Silverado
2011 Escalade ESV |
dtreat
Loc: Virginia
Reg: 10-25-20
02-23-21 04:53 PM - Post#2814963
In response to beagrizzly
A little more troubleshooting. If I put on the hub and just push it all the way on, it won't turn. Don't even need to put the nut on. So, getting stuck on something. Brakes all the way in, same thing. Brake pads off the car (I didn't want to have to put that spring back on again), same thing. New wheel cylinders... hmmm. Turns out the little nib on the top that the adjustment spring/holder is attached to is rubbing on the hub when all the way on. I am 99% sure that is what it is. I used some chalk on it, put hub on and it rubs the chalk off. Repeated on other side, does not do the same thing.
I'm thinking of filing down that nub a tiny bit and seeing what happens. Will probably unbolt and rebolt the cylinder first.
Anyone else seen this problem?
lobucrod
Loc: Slaton, TX
Reg: 10-01-07
02-24-21 04:45 AM - Post#2814984
Have the drums been turned? If you have new shoes and unturned drums maybe the new shoes are dragging on a lip in the drum.
'38 Chevy Coupe Gasser 409 powered
'50 Sedan Delivery 401 Nailhead powered
'62 Buick Electra original survivor
dtreat
Loc: Virginia
Reg: 10-25-20
02-25-21 05:26 PM - Post#2815091
In response to lobucrod
Thanks all.
It was indeed the new wheel cylinder. Had to file down the very top of it. Now the hub spins like a top when torqued 33 and packed off as the manual says.
02-25-21 08:05 PM - Post#2815103
Just out of curiosity, what brand are the wheel cylinders?
dtreat
Loc: Virginia
Reg: 10-25-20
02-26-21 05:25 AM - Post#2815113
assuming from China. I already threw out the boxed they came in. Got them here:
https://www.chevsofthe40s.com/detail/8094/Chevrole...
