Username Post: 1965 Impala Trunk Divider Board        (Topic#364418)
donzi544
donzi544
Reg: 04-18-20
02-21-21 03:30 PM - Post#2814823
How is the trunk divider secured on a 65 Impala? Another member posted a picture in another post of mine and I noticed his 67 had small tabs that poked through his divider board and then were bent over to secure it. I don't see any tabs on mine. Did the factory just use spray glue at the top and bottom and let the bottom rest on the metal shelf?
Here are a couple pictures of mine. The only way it lines up with the seat hooks is with the juke padding facing the seat. The 2 cutouts at the bottom don't line up with anything though. Is it possibly the wrong part? Thanks.
Attachment: PXL_20210221_220232340.jpg (3.63 MB) 4 View(s)
Attachment: PXL_20210221_221120448.jpg (4.67 MB) 2 View(s)
Attachment: PXL_20210221_221107714.jpg (3.4 MB) 3 View(s)
65 Impala SS, 327 300hp, 4 speed
sz0k30
sz0k30
Loc: Oakland Co., Michigan
Reg: 10-12-08
02-22-21 06:29 AM - Post#2814858
    In response to donzi544
I can't help you other than another photo of my 67. Definitely a big difference in the trunk divider area.
Attachment: P1000511.JPG (2.58 MB) 4 View(s)
Edited by sz0k30 on 02-22-21 06:30 AM. Reason for edit: No reason given.
68SS427
Loc: Connecticut
Reg: 12-01-07
02-22-21 07:22 AM - Post#2814862
What you show in the 2nd picture is the insulation. The actual divider board is a heavy black coated cardboard material that hangs on the same hooks as the rear seat back. It seems someone put the wrong sticker over the original insulation sticker. Don S
Don S.
1968 SS427 x 4
1968 Impala L-72
1969 Chevelle SS396
donzi544
donzi544
Reg: 04-18-20
02-22-21 09:35 AM - Post#2814871
    In response to sz0k30
Thanks for the picture. I can see the tabs much better. As you can see by my picture, I don't have those tabs and there is no way for the seat hooks to fit into anything on the divider board to secure it. The investigation continues. :-)
donzi544
donzi544
Reg: 04-18-20
02-22-21 09:38 AM - Post#2814872
    In response to 68SS427
Thanks for the reply Don. It is definitely a divider board. The other side of it is black cardboard and the juke padding/insulation is glued to it. I'm assuming that the black cardboard side faces the inside of the trunk because the 3 cutouts will only line up with the seat hooks that way and it would look better than the insulation showing in the trunk.
68SS427
Loc: Connecticut
Reg: 12-01-07
02-22-21 12:25 PM - Post#2814886
Oh, Ok Mike, when I bought mine years ago, there was no insulation on it, just the cardboard.
Don S.
1968 SS427 x 4
1968 Impala L-72
1969 Chevelle SS396
sz0k30
sz0k30
Reg: 10-12-08
02-22-21 05:13 PM - Post#2814906
Same with mine. But looking at your photo, in the top flange there is enough metal to easily with just a hacksaw cut a couple of tabs & bend them up to support the cardboard.
donzi544
donzi544
Reg: 04-18-20
02-23-21 11:29 AM - Post#2814943
Thanks everyone for the replies. I'm just going to use some spray glue, do a little trimming, and poke a hole for the speaker wires. I wonder what the 2 cutouts on the bottom of the divider board are for though?
steve65
steve65
Loc: New Westminster BC
Reg: 09-25-13
02-23-21 12:40 PM - Post#2814949
seat belts maybe????
Steve Duncan
66 Impala 2dr Coupe
Not sure of color yet
work in progress
Execution time: 0.123 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:05 PM
