donzi544
Reg: 04-18-20
02-21-21 06:08 AM - Post#2814778
1965 Impala SS 2 Door
Anyone know what this part is called and/or have a GM part number for it? It is under the rear seat, passenger side. The antenna and speaker wires run under it. There is a number (3802W16) stamped on the top but it doesn't seem to correspond to a proper GM part number and I can't find any info on it. Thanks.
65 Impala SS, 327 300hp, 4 speed |
Site Ambassador
02-21-21 07:46 AM - Post#2814782
In response to donzi544
I couldn’t tell you what it came from, but if it were factory it would be spot welded in place, not held down with screws. It looks like a floor brace from something else that has been repurposed to protect the wires that are under it from chafing.
1957 Cameo Carrier |
bbcrtny
Reg: 07-01-10
02-21-21 08:35 AM - Post#2814786
If you look at the Accessory Installation Manual
for rear antenna or rear speaker is doesn't show a part like that. http://toms427impala.info/CT/65AccessoryManual .pdf
sz0k30
Loc: Oakland Co., Michigan
Reg: 10-12-08
02-21-21 11:57 AM - Post#2814801
In response to wagonman100
I have the identical piece on my 67 Impala. It fits the floor profile perfectly so I doubt that its repurposed. Sure looks like a factory piece to me. Mine is also held with screws. Would be pretty difficult to fish wire/cable if it was riveted on.
Edited by sz0k30 on 02-21-21 12:06 PM. Reason for edit: No reason given.
bigred65
Loc: Kenmore WA
Reg: 03-18-13
02-21-21 12:06 PM - Post#2814804
Mike, I'm reasonably sure it is factory as I have seen 2 others in cars and I removed 1 out of a parts car. It is screwed on because the wires need to be serviceable. They only used it in very few cars, I'm not sure why some cars got it and most didn't. I've been around several hundred cars and only seen it twice before and now 3 times with your car. I haven't been able to find any more info on it. Good luck hope this helps.
Brandon
1965 Impala SS 396 4spd
1966 Impala SS convert 4spd
1973 Corvette 4spd
1973 Firebird Formula 4spd
1959 Corvette FI 4spd will restore it someday!!! |
Gaspains
Loc: Mankato, MN
Reg: 11-23-09
02-21-21 12:38 PM - Post#2814807
In response to bigred65
Pretty sure it's a Fisher body part as mine has had it since I bought the car in '75. My car was built in St. Louis. And mine is screwed down as well.
If it's that rare, I wonder if my car is worth more. Haha!
Kevin
1965 Impala SS Coupe
Regal Red with Black Interior
L74 327
M-20
3.31 Open, 12 bolt
65-66 FSCC #512
NIA #2832 |
donzi544
Reg: 04-18-20
02-21-21 02:34 PM - Post#2814815
In response to sz0k30
Thanks for your reply. At least I can expand the search to up to 1967 Impalas now, instead of it being the typical one off 65 part. :-)
Your second photo was helpful too regarding a question I have about installing a trunk divider. I'll post another thread about it later.
Edited by donzi544 on 02-21-21 02:48 PM. Reason for edit: No reason given.
donzi544
Reg: 04-18-20
02-21-21 02:35 PM - Post#2814816
In response to Gaspains
Mine was built in St. Louis too. I wonder if that is why the part is rare. Thanks for the reply.
donzi544
Reg: 04-18-20
02-21-21 02:39 PM - Post#2814817
Thanks for the reply Brandon. Someone else on an Impala Facebook forum mentioned that only Impalas with rear antennas had that part and not many had that. Not sure if that is the reason for the rarity though.
donzi544
Reg: 04-18-20
02-21-21 02:47 PM - Post#2814818
I did a Google search for "Fisher Body 3802W16". I didn't find anything. Anyone have a Fisher Body Parts Manual they can look in to maybe find a name for the part or a cross reference GM part number? I have the Assembly Manual and the Chassis and Body Parts & Illustration catalogs but I don't see anything in those. Thanks.
bigred65
Loc: Kenmore WA
Reg: 03-18-13
02-21-21 02:55 PM - Post#2814819
I've had a lot of cars with rear antenna and not one had it. Never had a st. Louis car although.
Brandon
1973 Corvette 4spd
donzi544
Reg: 04-18-20
02-21-21 03:17 PM - Post#2814820
Thanks Brandon. The St. Louis angle makes more sense for the rarity of this part. I wasn't sure about the rarity of a rear antenna.
Gaspains
Loc: Mankato, MN
Reg: 11-23-09
02-21-21 03:30 PM - Post#2814822
There has to be a Fisher body manual out there someplace as Tom has been promising that it's "coming soon" in the reference section. (No offense Tom!) Someone must have one. I'm sure there are those of us who would be willing to scan it and make it available as a resource
Kevin
L74 327
M-20
3.31 Open, 12 bolt
65-66 FSCC #512
NIA #2832 |
BillM89
Reg: 01-22-20
02-21-21 04:36 PM - Post#2814824
Hello, I have a 65 Georgia built Impala SS without a rear antenna, and it has this wire channel in it and it was screwed in place. Due to rear glass water leakage, I welded in a new underseat panel. The front curved section of the channel ,about 4 inches long, was solid with a little surface rust, but the whole back section was garbage. I cut off the front section and duplicated the rest of it by bending up and welding a new rear section.I had no luck finding any info on this piece either, so I just remade it.
sz0k30
Reg: 10-12-08
02-21-21 04:48 PM - Post#2814825
In response to BillM89
My 67 was built in Atlanta and has U73 - manual rear antenna
docjns1
Loc: upstate NY
Reg: 11-12-19
02-21-21 07:03 PM - Post#2814833
Doraville Ga built here, no rear antenna and no such part.
Perhaps an afterthought or (dealer installed?) accessory add-on for those w/rear antenna to protect wiring and keep in its place? There doesn't seem to be the tabs on the floor pan like driver's side for the flat body harness.
Steve
327 / 300 L74
M11 3 on the tree
12 bolt 3.31 open dif |
Oshawa65SS
Loc: Grande Prairie AB & N...
Reg: 09-22-14
02-21-21 10:17 PM - Post#2814844
It's for factory order rear antenna cars.
You'll also find wire clips screwed along the trans tunnel too.
Dealer rear antenna cars just had the cable taped down instead, and that metal protector was also not part of the 986103 antenna kit for 65 full size.
Ryan
Build date Dec. 21 '64 Oshawa |
Oshawa65SS
Reg: 09-22-14
02-21-21 10:24 PM - Post#2814845
As for some factory rear antenna cars having it vs some not, it could be a running change added later in 65 production (since it's been seen on later years too), or there were supply interruptions, or the worker didn't bother, who knows.
Ryan
68SS427
Loc: Connecticut
Reg: 12-01-07
02-22-21 06:42 AM - Post#2814859
In response to Oshawa65SS
Two of my Impalas have factory rear antennas. One is a Los Angeles built, the other is Tarrytown. both cars have that cover under the seat.
Don S.
1968 SS427 x 4
1968 Impala L-72
1969 Chevelle SS396 |
Edited by 68SS427 on 02-22-21 08:26 AM. Reason for edit: No reason given.
Gaspains
Loc: Mankato, MN
Reg: 11-23-09
02-22-21 07:50 AM - Post#2814865
In response to 68SS427
The cover in mine only protects the seat speaker wire as the factory antenna is on the front fender.
Kevin
L74 327
M-20
3.31 Open, 12 bolt
65-66 FSCC #512
NIA #2832 |
Oshawa65SS
Reg: 09-22-14
02-22-21 09:17 AM - Post#2814870
Great info Kevin that the cover was used to protect the wiring for a factory rear seat speaker, or rear stereo speakers on their own, or in combination with a factory rear antenna.
I wonder about the vacuum trunk release hose?
Was it a factory option in 65?
Is the cover big enough to fit the hose and antenna cable and speaker wires?
What about how many things the trans tunnel wiring clips could fit too?
Ryan
donzi544
Reg: 04-18-20
02-22-21 09:47 AM - Post#2814873
Thanks for all the reply's everyone. I guess the St. Louis connection is a bust. Bill, it was also recommended on another Facebook group that I would probably have to take the old one to a metal shop and have them make one. That will be my last resort, I guess. I'm trying to keep this car all original, if I can. If someone ever comes across this part for sale, please contact me. Hopefully, swap meets will get back into full swing soon and maybe I'll get lucky at one. :-)
sz0k30
Reg: 10-12-08
02-22-21 12:27 PM - Post#2814887
Since its hidden under the seat and no one will ever see it, why not just sandblast & paint it?
Site Ambassador
02-22-21 06:41 PM - Post#2814909
Wow, that’s a lot of responses. I just wanted to clarify what I was saying. I was saying if it were some kind of brace, it would be welded. Since it seems to be there from the factory and it’s purpose is to protect the wires, then it makes sense that it is screwed down instead of welded. I don’t think the number is a part number. It does not follow the typical GM part number protocol. It may be a stamping number from the manufacturer. If you want to replace it, Eastwood sells remade braces similarly shaped, but it me be a little difficult to put a bend in it to follow the floor contour.
fsc66
Loc:
Reg: 05-05-12
02-23-21 06:00 AM - Post#2814931
Vacuum trunk release was a dealer installed accessory, not factory installed.
paul
Gaspains
Loc: Mankato, MN
Reg: 11-23-09
02-23-21 06:07 AM - Post#2814932
Ryan
Certainly will hold the wiring and antenna cable. As Paul notes, vacuum trunk release was dealer installed.
I actually ran my rear deck speaker wires through it back in the 8-track days. Of course, I didn't have an antenna wire to contend with.
Kevin
L74 327
M-20
3.31 Open, 12 bolt
65-66 FSCC #512
NIA #2832 |
Oshawa65SS
Reg: 09-22-14
02-23-21 08:58 AM - Post#2814938
Ok, good to know it's for speaker(s) wiring and antenna cable only.
I have a complete vacuum trunk setup to install except the trunk lid vacuum cylinder is for a 63/64 Buick Riviera instead of my Impala.
Trico P90451-3 instead of P90451-14
Ryan
59fins
Member #212 "20th Year" Gold Supporting Member
Loc: Surprise Az USA
Reg: 04-07-00
03-01-21 01:07 PM - Post#2815347
I pulled one out of a 67 Buick Riviera GS in Vegas this last Saturday, it was solely used for the vacuum trunk release vacuum hose.
donzi544
Reg: 04-18-20
03-01-21 01:34 PM - Post#2815348
In response to 59fins
Want to sell it?
BillM89
Reg: 01-22-20
03-02-21 07:31 AM - Post#2815406
Hello, One place you could check is Chevy Parts of Assonet here in Massachusetts. He's supposed to have a lot of NOS stuff along with a yard full of early Chevys. If we can get through the rest of the pandemic, I am going to go there and check it out myself. If you Google it, they have a website with all the info.
