Username Post: Distributor touching firewall        (Topic#364400)
MTPat
Reg: 07-25-20
02-19-21 09:19 AM - Post#2814626
68 C10 w/GM HO4 350 - gas anyone had this problem? If so, can you suggest a fix?
02-19-21 02:56 PM - Post#2814652
    In response to MTPat
Hei coil in cap dist? What was in there before this was an issue, need some omitted info here.
Edited by Shepherd on 02-19-21 02:57 PM. Reason for edit: No reason given.
MTPat
Reg: 07-25-20
02-20-21 09:58 AM - Post#2814705
HEI coil in cap. Previous engine was a 230 6cyl. Used engine mounts (perches) from a 69 GMC with a V8.
02-20-21 10:02 AM - Post#2814707
Assuming the engine is at the right angle,Maybe an hei with divorced coil is called for.
69_BOWTIE
Loc: WYOMING,USA
Reg: 02-27-02
02-21-21 01:53 PM - Post#2814812
Mine was real close to firewall ,I had to move my #1 tower on cap over 1 so I could get it timed right.Never had any real issues here,I replaced trans with a 700 r and was able to move eng. forword to the front hole.
2001 Silverado 4X4
2005 FXDWGI
69 CHEVY Short Step
63 IMPALA 2/DR HRDTOP 327
Mel Foye
Mel Foye
Reg: 09-29-00
02-28-21 02:17 PM - Post#2815284
My 69 Suburban with a HEI was just a drop in. Coil on top. I looked up mounts and perches and they were same for Chev and GMC with V8. Never worked on a V6 setup, instead of 69 GMC what if 68 GMC V6
perch/mounts were given to you?
Execution time: 0.031 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:16 AM
