1Nighttrain
Reg: 09-10-19
02-17-21 05:51 PM - Post#2814488
Hello
I’m looking to see what everyone is using for a intake manifold.
I have a 396 in my 65 Impala, I’m running the cast Holley intake with a Edelbrock carb.
I’m leaning towards the Edelbrock performer or the RPM.
What ya got ?
1965C-10
Loc: San Tan Valley AZ "Phoeni...
Reg: 11-18-01
02-18-21 08:38 AM - Post#2814518
In response to 1Nighttrain
1968 C10 pick-up version of 396, has GM aluminum intake, got engine and transmission (396 and TH400) from a 1974 C10 pick-up, swapped into 1965 C10 that came with 283 small block from factory.
No idea what the factory aluminum intake came from, running Edelbrock Qjet 850 on it.
busterrm
Loc: Wichita Falls, Tx
Reg: 08-30-10
02-18-21 09:43 AM - Post#2814525
In response to 1965C-10
For a street machine, Edelbrock makes the AirGap! Its a very good intake for street and mild strip. Factory intake from that era don't flow very well.
==== BOB ====
If I can't smoke the tires I want more!
1976 Chevy Nova
2017 Harley Davidson XL1200 Sportster
2018 Nissan Versa Note |
1965C-10
Reg: 11-18-01
02-18-21 11:39 AM - Post#2814533
In response to busterrm
It's being replaced with Edelbrock Pro flo 4 fuel injection.
It comes with a new single plane intake, since the intake only flows air (VS wet flow like a carb and needing dual plane), has 8 injectors at the ports, should maybe make better power.
Just hoping it runs really good.
https://www.edelbrock.com/pro-flo-4-efi-system- for...
Edited by 1965C-10 on 02-18-21 11:40 AM. Reason for edit: No reason given.
65OldSchool
Loc: Western Washington
Reg: 10-27-20
02-18-21 04:25 PM - Post#2814559
'65 with 396/325.
Edelbrock Performer RPM intake
Edelbrock Performer RPM Alum. heads.
Holley Street Avenger 770 carb
Mild cam
Very satisfied with this combo
Bart
1965 SS 396 4-Speed
Tuxedo Black |
1Nighttrain
Reg: 09-10-19
02-18-21 08:47 PM - Post#2814584
In response to 65OldSchool
Thank you , this is what I was looking for someone with the rpm intake installed on a big block, any issues with the air filter and hood clearance ?
Johnny468
Loc: Richmond, Va.
Reg: 10-24-08
02-19-21 09:39 AM - Post#2814630
I have a Performer RPM Air Gap intake on a 454 in a 65 with stock steel hood. No problem with hood clearance. Performer RPM and Performer RPM Air Gap are the same height, so either one will fit. I have a Holley 4150 style carb with a thick carb base gasket and a Moroso drop base air cleaner with a 14x3 K&N filter. You can actually fit a 14x3.5 filter but hood clearance will be tight.
Hope this helps.
Johnny
1965 Impala SS
505/4-speed/3.90
1Nighttrain
Reg: 09-10-19
02-19-21 10:19 AM - Post#2814636
In response to Johnny468
Yes Sir, thank you this is the information that I’m looking for .
65OldSchool
Reg: 10-27-20
02-19-21 12:32 PM - Post#2814645
My clearance is tight, but it works. I have a dropped air filter base,(that is a must) with a K&N 3" filter and K&N Air Flow top. (those tops have a crown to them)
A great trick for finding clearance, is to loosely make a "ball" out of aluminum foil and then carefully close your hood. Obviously, you can determine if you don't have enough clearance, but if your hood latches, and the aluminum ball is deformed, measure the remaining height of the ball. That will determine your clearance to the underside of hood.
Bart
1965 SS 396 4-Speed
Tuxedo Black |
1Nighttrain
Reg: 09-10-19
02-19-21 02:27 PM - Post#2814650
Thank you Sir, beautiful setup.
Johnny468
Loc: Richmond, Va.
Reg: 10-24-08
02-19-21 03:20 PM - Post#2814654
Just be aware that some drop base air cleaners will not fit Edelbrock carbs.
Johnny
1965 Impala SS
505/4-speed/3.90
1Nighttrain
Reg: 09-10-19
02-20-21 01:15 PM - Post#2814728
Thank you Sir
We need a like button
02-20-21 10:36 PM - Post#2814767
busterrm
Reg: 08-30-10
02-23-21 11:39 AM - Post#2814944
Edelbrock's Air Gap has bosses next to the intake ports on the heads, so it can be drilled and fitted with injectors. I have seen a few in our Nova club here with tuned port injection on a Air Gap intake. They love it, they say they have better throttle response the Air Gap intake.
==== BOB ====
1976 Chevy Nova
