Username Post: Starting a 55 build        (Topic#364366)
Daleici
Gold Supporting Member
Daleici
Loc: Cumming, Ga
Reg: 02-10-21
02-17-21 10:03 AM - Post#2814456
Hello all,
So I purchased an all original 55 bel air with the intent of making it a daily driver. I will keep all the original parts on a pallet, but will replace quite a few.
We plan on a "Connect and Cruise LS3(430hp)/4L70-E", Currie 9" With 3.0 gears. Disk brakes all around. A Ridetech StreetGrip kit, someones A/C kit, and someones power steering setup.
I have only purchased the car at this point.
Any suggestions you folks may have are appreciated!
Thanks,
Dale
Attachment: Dena_and_Dan_1_Reduced.jpg (269.21 KB) 4 View(s)
Front View
rcr3
Site Ambassador -"17th Year" Silver Supporting Member
rcr3
Loc: MANHEIM PA. U.S.A.
Reg: 11-24-02
02-17-21 10:06 AM - Post#2814458
    In response to Daleici
Nice car,good luck with the project!
'67 Camaro survivor
'06 Z71 Sierra Ex Cab
'37 Chevy cp.SOLD!!6/7/14
'73 Nova pro-street project
'17 Chevy Trax LT
02-17-21 03:46 PM - Post#2814476
    In response to rcr3
Looks like a great start. Sounds like the right systems to go for.
Daleici
Daleici
Loc: Cumming, Ga
Reg: 02-10-21
02-18-21 04:49 AM - Post#2814506
I hope so, still trying to figure it all out. Like what brakes with which wheels, what steering gear, hydro or electric, if hydro 20:1 or 14:1, do I need headers or do I have enough clearance with the stock manifolds.
Other questions in my head:
Should I go coil over or stay with the leaf's
Do I need a in tank pump, or is an external system quiet enough.
So before I go on anything I will hopefully have a good understanding of the finished product.
I'm reading posts and I appreciate everyone's knowledge here.
Dale
Attachment: Side_View_1_Reduced.jpg (254.54 KB) 2 View(s)
Side view
Algoma56
Reg: 03-14-05
02-21-21 03:20 AM - Post#2814771
Nice car, nice plan. If you do go with an overdrive transmission, put some lower than 3.00 gears in the back. Say 3.70, you'll enjoy the car a lot more, and it will still run well on the highway.
Daleici
Daleici
Loc: Cumming, Ga
Reg: 02-10-21
02-25-21 12:18 PM - Post#2815071
    In response to Algoma56
Thanks for the reply!.
We have been changing our build plan a bit, and have decided to put a new frame under the body. Looks like I'm leaning toward the Roadster Shop REVO setup. We are also going to change our powertrain choice to an LT1/8L90-e connect & cruise setup. I'm going to leave the rear gear at 3.00 for the 8L90 since it has a stump puller 4.56 first gear. With the rear tire being a 245/50/17 that will allow an 80 mph cruise at 2000 rpm.
Still tweaking this.
Dale
Algoma56
Reg: 03-14-05
02-26-21 08:37 AM - Post#2815128
Good! You have to look at both ends-effective first gear and final drive. The 8-series transmission changes decision on rear gear ratio. You're planning it right.
Daleici
Daleici
Loc: Cumming, Ga
Reg: 02-10-21
02-28-21 02:46 PM - Post#2815286
Thanks, still a few more tweaks. Going to forget the LT1 and move to an LS3 W/6L80-E trans (4.06 1st gear, .67 overdrive).
The frame will more than likely be a Nerd Rods C4 frame using either a Dana 36 or a 44. If we go with the 480 horse LS3 then I'll choose the 44. I'll use the stock Vette Gear ratio.
Nerd Rods says that 245/45 R17 on the front and 275/40 R18 on the rear will fit without body mods, but I believe there is at least 1 mod the the body for fitment.
I would like to retain the spare tire hole so I believe that a 25 gallon tank will fit.
Execution time: 0.113 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:21 AM
