Username Post: 1973 Chevelle/Malibu For Sale in NY        (Topic#364276)
engvie
Reg: 02-03-21
02-08-21 05:30 AM - Post#2813846
2 Door Colonnade coupe. 350 auto, bucket seats w/ console. Round gauge pods with factory tach. Centerlines. A/C and Heat. "Drive" movie clone car. Primer grey with saddle interior. 8-cyl. 350cid/145hp 2bbl L65. Car is all stock besides wheels and exhaust.
Turbo 350 Automatic.
Non-Posi Rear End.
Factory A/C & Heat. The Heater works. A/C Compressor turns.
Factory Round Gauge Package with Factory Tach
New true Dual Exhaust from stock exhaust manifolds with Flowmasters dumped at axle.
New Windshield
New Fan Clutch
Fresh Major Tune-Up: All AC/Delco parts used
Runs, starts and drives well.
Car is a Strong Driver.
Original Dark Brown Exterior.
Original Dash Pad is Perfect and has Zero Cracks anywhere.
All brake lines and P. Valve were replaced
Needs some rust areas patched on the rear quarters, bottom of door corners, bottom of fender corners at door and in the windshield cowl area. Windshield Channel is solid. Floors, frame and rockers are very solid. Trunk pan is soft and starting to poke thru and the tail panel around the taillights have small holes but nothing that can't be worked back.
Can't confirm but I believe the mileage is 98,000 original and not 198,000. Looks to have the factory installed Engine, Trans, Carb, Rear End , Harrison A/C Compressor, point distributor, interior including loop carpet, windshield wiper blades, owners manual including warranty booklet, etc. Some extra Misc. trim pieces included and 3 of the original steel wheel hubcaps. Car is unmolested, very original and was taken care of over the years. Not many 73's around anymore.
Hagerty values the car at $7,200.00 #4 Fair Condition E-Mail dominicyt3k@hotmail.com or text if interested. six 3 one-5 six 8-1 three eight 3
Edited by engvie on 02-11-21 01:32 PM. Reason for edit: No reason given.
Execution time: 0.096 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:04 PM
