Username Post: Throwout Bearing        (Topic#364230)
Chevi
Loc: Eastern NC
Reg: 07-13-08
02-04-21 01:42 PM - Post#2813616
What determines the length of the throwout bearing. I have a stock 57 283 with all original clutch related parts. I installed a muncie 4 speed and will purchase a new clutch pressure plate assembly. Which throwout bearing is correct; short or long? Thanks, Chevi
Member #409
02-04-21 06:43 PM - Post#2813631
    In response to Chevi
The original pressure plate has a "flat" diaphragm spring and takes a long throwout bearing.
Later model pressure plates and performance pressure plates have a conical or "raised finger" diaphragm spring and take the short throwout bearing.
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
02-05-21 08:36 AM - Post#2813668
Links you may find helpful:
https://www.chevytalk.org/fusionbb/showpost.php?po...
Pete
Rucco49
Reg: 07-25-19
02-28-21 10:23 PM - Post#2815316
    In response to japete92
Great topics, Pete. My uncle is looking to get this 283 as the next project after we finished installing the suspension from 4Wheelonline onto the Wrangler and clear the garage.
Execution time: 0.172 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:19 PM
