Username Post: Throwout Bearing        (Topic#364230)
Chevi
Loc: Eastern NC
Reg: 07-13-08
02-04-21 01:42 PM - Post#2813616
What determines the length of the throwout bearing. I have a stock 57 283 with all original clutch related parts. I installed a muncie 4 speed and will purchase a new clutch pressure plate assembly. Which throwout bearing is correct; short or long? Thanks, Chevi
Member #409
02-04-21 06:43 PM - Post#2813631
    In response to Chevi
The original pressure plate has a "flat" diaphragm spring and takes a long throwout bearing.
Later model pressure plates and performance pressure plates have a conical or "raised finger" diaphragm spring and take the short throwout bearing.
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
02-05-21 08:36 AM - Post#2813668
Links you may find helpful:
https://www.chevytalk.org/fusionbb/showpost.php?po...
Pete
Execution time: 0.098 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:49 PM
