Username Post: Molding removal?        (Topic#364185)
underdog66
Loc: Pa.
Reg: 01-30-21
01-31-21 10:39 AM - Post#2813340
Can anyone tell me how to remove the chrome outside molding at the rear quarter window? This is on a 55 Chevy 4 door Bel Air.
craig32
Loc: PA
Reg: 08-05-07
01-31-21 02:50 PM - Post#2813362
    In response to underdog66
I take it you mean the 'sail' panel trim? If so, I believe you have to remove the inside trim and the glass, and the upper portion has a clip at the top (by the door) that is either a push clip or a stud with a nut. At the very point (at the back) there is a stud/nut that is inside the trunk. The bottom piece is separate, I don't remember how it attaches at the moment (it's been 6 years!) but you'll be able to see it from the inside.
Hope that is the pieces you were talking about - good luck!!
66 Impala (almost done!)
56 Stepside shortbed
55 Bel Air sedan
81 Corvette
02 Monte Carlo (bought new)
underdog66
Loc: Pa.
Reg: 01-30-21
02-01-21 12:17 PM - Post#2813414
    In response to craig32
Thanks for the info. I'll try it tomorrow.
Execution time: 0.062 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:18 AM
