Username Post: spark plug boot too tight        (Topic#364160)
Big T
"15th Year" Silver Supporting Membe
Big T
Loc: Simi Valley CA
Reg: 04-14-06
01-29-21 03:08 PM - Post#2813220
350 ho #6 cap "boot" is touching the fire wall. Motor is already moved 3/4 inches forward.
Is there a simple fix other than putting dent in the fire wall' ouch!!
can I shave any off the back top edge of the boot----maybe 1/16 "
tom
Tom
55 4 door BelAir
Member #409
01-29-21 03:46 PM - Post#2813222
    In response to Big T
I am assuming you have a big cap HEI.
If you trim the boot, the spark for that cylinder will short out to the firewall. HEI's are bad about that even with good boots and more clearance.
Big T
Big T
Loc: Simi Valley CA
Reg: 04-14-06
01-29-21 10:19 PM - Post#2813238
    In response to Rick_L
thank you rick it is the large cap
Tom
55 4 door BelAir
56sedandelivery
Gold Supporting Member
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
01-29-21 11:02 PM - Post#2813240
Maybe a little WD-40 inside the boot before it goes on, just a touch however. You don't really want to use an oil based product on rubber parts at it does dissolve rubber. I am Butch/56sedandelivery.
Site Ambassador
01-30-21 08:34 AM - Post#2813255
You can get one of these caps. It arranges the wires to the side. All odd cylinders on the left side and even on the right.
https://performancedistri butors.com/product/dui-cr...
1957 Cameo Carrier
Member #409
01-30-21 08:39 AM - Post#2813257
    In response to wagonman100
"Crossfire cap" is a good name for that. It will have the spark going to the wrong cylinders (crossfire) in no time. Far worse than a short to the firewall.
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
01-30-21 09:48 AM - Post#2813262
There are 'small cap' distributors available. Simply add a separate coil (like GM did). I recommend an oil filled/cooled coil over and epoxy cooled type.
One of many:
https://www.summitracing.com/parts/msd-8560?seid=s ...
Pete
Site Ambassador
01-30-21 04:20 PM - Post#2813285
No it won’t. It has the brass routed to go from where the rotor makes contact to the correct tower for the firing order encased in the plastic. We used one on my friend’s Nova that I converted to large cap HEI and had no room to route the wires around the cap as you normally would. Worked great. It neatens up the look of the wires as well.
1957 Cameo Carrier
Bad56Sedan
Bad56Sedan
Loc: Pasadena, Texas
Reg: 04-29-04
01-31-21 09:44 AM - Post#2813335
If you are that close already and you are apparently concerned,
possibly replace that HEI with the other GM HEI that is smaller in diameter?
Or replace with one of the smaller diameter after market distributors?
But to be 3/4" forward you would think it should fit so I wonder if you have other possible issues.
Possible motor/trans mount issues and the engine /trans has dropped a bit?
VC56S 2 door Sedan, 40 Years
Execution time: 0.097 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:13 AM
