Username Post: 57 sports coupe high beam light        (Topic#364139)
Nudge78
Reg: 01-26-21
01-27-21 10:14 AM - Post#2813085
Hi there I have not long brought a Belair sports coupe, I took it for a warrant of fitness for the first time and it has failed on ‘ no high beam light on the dash, can someone tell me where this usually would be ? There is a bow tie on speedo that lights up red but stays on while the lights are on but they are saying I’m meant to have a blue high beam light, thanks
01-27-21 03:31 PM - Post#2813095
    In response to Nudge78
What year model? Right or left hand drive?
The bow tie on the instrument cluster lights up red, on US cars, when the high beam headlights are on. The bulb wire (light green) is connected to the headlight dimmer switch under the floor on a 55/56 and to the firewall connector on a left drive 57 and is spliced to the light green wire, in the harness, on a right drive.
Nudge78
Reg: 01-26-21
01-28-21 12:42 AM - Post#2813119
    In response to acardon
Hi it’s a 1957 Belair sports coupe, it’s left hand drive, I believe it was imported around 6 or 7 years ago, thanks
01-28-21 06:56 AM - Post#2813123
Does the light stay on when you switch to low beam with the floor mounted dimmer button? If so, one of the instrument bulb sockets may be in the high beam location on the speedometer. Does one of the other dash lights go out when you change from high to low beam? They may be switched.
Link to instrument cluster.
The plastic bow tie lens may have to be changed to blue.
Edited by acardon on 01-28-21 06:58 AM. Reason for edit: No reason given.
Site Ambassador
01-28-21 08:46 PM - Post#2813173
The bow tie should light up red when the high beams are on and go out when the high beams are turned off.
1957 Cameo Carrier
Nudge78
Reg: 01-26-21
01-28-21 10:43 PM - Post#2813180
The red bow tie does stay on until ya turn the lights off, or if you turn the light switch to the right, the button on the floor does nothing to the bow tie light. Thanks
01-29-21 12:38 PM - Post#2813205
As mentioned, the high beam indicator bulb is swapped with one of the other instr4ument lights. Does one of the other instrument lights go out when you change to low beam?
55 Shaker
Loc: north central IL.
Reg: 03-13-06
01-29-21 03:51 PM - Post#2813223
As arcardon says, the high beam indicator bulb will have a green wire going to it. The instrument cluster bulbs should have grey wire going to them. Some one has the bulb sockets plugged in the wrong hole in the back of the instrument cluster.
warpwr
warpwr
Loc: Santa Clara, CA
Reg: 04-11-06
01-30-21 11:02 PM - Post#2813309
    In response to 55 Shaker
If you have an instrument light in the high beam indicator socket it will dim to off with rotation of the headlight switch.
Vaughn
56 Delray 327, 5 spd
Nudge78
Reg: 01-26-21
01-31-21 01:52 AM - Post#2813311
Thank you everyone
Execution time: 0.072 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:42 AM
