Username Post: Bucket seat mounts        (Topic#364131)
BG
Reg: 09-12-07
01-26-21 05:05 PM - Post#2813017
I put bucket seats in my 57 wagon but I know I need to add large metal washers or plates under the floor but thought I’d ask others what they did or suggest. Thanks
01-27-21 03:44 PM - Post#2813096
    In response to BG
I channeled the inboard mount with welded in 3/16 angle iron. The outboard mount has a plate under the floor.
https://www.trifive.com/cdn-cgi/image/format= auto,...
BG
Reg: 09-12-07
01-27-21 04:02 PM - Post#2813098
    In response to acardon
Did the outer plate run front to back? What’s the approximate size and thickness?
Is there someone that knows the aluminum Powerglide real good that I could ask the questions I posted?
Member #409
01-27-21 04:26 PM - Post#2813101
    In response to BG
The outer plate does run front to back and is what the fasteners for the original seat are attached to. Recommend you use them.
There's two ways to do the mounting brackets. The floor near the tunnel is 1-1/4" higher than at the original seat mounts. acardon's way was to drop the floor using the tunnel he showed. The other way is to put a spacer between the seat's outer side and the floor, fastening the spacer to the original seat mounts in the floor, and to the seat's structure.
Execution time: 0.074 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:03 AM
