Username Post: turn signal and brake lights        (Topic#364116)
498 chevy
"13th Year" Platinum Supporting Member
498 chevy
Loc: hayward ca.
Reg: 09-28-07
01-25-21 02:38 PM - Post#2812907
hello all, i built a 27 ford bucket this yr. wired the brake lights in and all ok. Lights back and front ok to. have a stand alone turn signal switch on column from speedway. LED lights out back. When I apply brake pedal the turn signal lights on the dash come on dimly, brake lights work fine out back. the turn signal work fine with turn switch. turn signal flash out back fine even if brake is on. turn indicator dash gos off when u let off the brake pedal. I leave the battery connected and no shorts. all wiring has there own connector on terminal block. I cant figure how the turn dash lights a getting fed back from the brakes. PS have a flasher from speedway for LED lights
Edited by 498 chevy on 01-25-21 02:40 PM. Reason for edit: No reason given.
01-25-21 04:39 PM - Post#2812921
    In response to 498 chevy
Steel or fiberglass? Do the front turn signals come on dimly when you apply brake? The turn indicators are connected to the front turn lights. The turn switch may be the culprit, feeding to the front. Do you have good grounds on all corners?
Edited by acardon on 01-25-21 04:41 PM. Reason for edit: No reason given.
monty56
monty56
Reg: 04-26-04
01-26-21 08:54 AM - Post#2812978
I found that I needed a "grounded" flasher w/ led lites not an "LED" flasher.
Monty
2001 Chevy Suburban 2500
2009 Saturn Vue w/20's
Monty's 56 Truck
Avatar is my Truck
498 chevy
498 chevy
Loc: hayward ca.
Reg: 09-28-07
01-26-21 02:45 PM - Post#2813003
    In response to acardon
Hi all wiring grounded to battery. No front turn signal light dimly lit with brake, only dash lights come on with brakes. front signal lights connected, working correct. I played with turn signal switch and I can get the dash turn signal lights to go off in one spot, but if I dont hold it they come on with brakes. Did look at wiring diagram for A5007 turn signal switch and it shows one wire going to brake light switch. I have brakes witch wired by it self. maybe its the wonderful speedway switch.
498 chevy
498 chevy
Loc: hayward ca.
Reg: 09-28-07
01-26-21 02:50 PM - Post#2813004
    In response to monty56
hi this is one thing I didnt check. great idea. I think I,ll just get a grounded flasher (cheap) and see what happens
498 chevy
498 chevy
Loc: hayward ca.
Reg: 09-28-07
01-26-21 02:54 PM - Post#2813005
hi crap I just checked the flasher and its grounded.
01-28-21 09:32 AM - Post#2813130
That sounds like your problem.
02-07-21 07:15 AM - Post#2813779
LEDs are directional. Do they make LED's for flashing? I had to remove side marker LED bulbs on my truck. The LEDs didn't flash.
'08 GMC Acadia 3.6L SLE
498 chevy
498 chevy
Loc: hayward ca.
Reg: 09-28-07
02-08-21 10:55 AM - Post#2813866
Hi led stop/turn signal lights work fine the way they are suppose to. The cheap turn signal switch is the problem. It has a bolt that go's through it to hold it to together. Turn Switch handle wobbled. It was loose so I tighten it. WRONG!!! dont do it made the little contacts between the stop and turn signal touch. I loosened the little bolt and the problem solved. That's what I get for trying to do it right. :smile :
Execution time: 0.092 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:53 AM
