Username Post: Aftermarket wheels for 58 impla        (Topic#364105)
Meyer
Reg: 11-01-19
01-24-21 07:46 AM - Post#2812808
What backspace and tyresize ?
I think 18” Dia
Jens
"12th Year Silver Supporting Member" & 58-60 Subject Matter Expert
Jens
Loc: Iowa.
Reg: 04-21-02
01-24-21 02:32 PM - Post#2812829
    In response to Meyer
I have 255/45/17s on mine with 17x8 wheels and 4” back spacing (zero offset). Tires are 10” wide with with no interference.
You can do 18x8 in that size with 255/45s but that would be about the max in the stock wheel well. Here’s a link:
https://youtu.be/19oBiCLU8U8
Jens
Jens
Loc: Iowa.
Reg: 04-21-02
01-24-21 03:02 PM - Post#2812836
Here’s 255/45/18s on 18x 8.5” rims with +6mm offset on the 59 1/2. Same 10” width as the 58 but an inch taller.
Attachment: DB44DDD8-A2E9-43B7-8F5E-DED91BCB2996.jpeg (3.66 MB) 3 View(s)
mahlmann
mahlmann
Loc: Las Cruces, NM
Reg: 01-20-11
01-24-21 03:07 PM - Post#2812837
    In response to Jens
I have American Racing VN 420 Classic 200s Polished
17"x 8" with Coker American Classic Radials 235/55 R17 1 3/4" whitewall 27.17" diameter 6.7" tread width
Attachment: NewImpalaWheels2__2_.jpg (2.58 MB) 8 View(s)
Mike Ahlmann
Las Cruces, NM
'50 Tin Woodies (two) Ramon and Willard
'58 Impala Sport Coupe
'69 El Camino SS-396
'07 Ford F150 to haul parts for above
'16 Ford Explorer 3.5 EcoBoost - Red Rocket
Meyer
Reg: 11-01-19
01-25-21 11:54 AM - Post#2812893
    In response to mahlmann
What backspace
Delray_58
Loc: Scotts Valley, CA
Reg: 03-20-10
01-26-21 07:15 AM - Post#2812968
Here's what I have on my Delray, with no rubbing or interference:
Front: 17x7, 4.0" backspacing, 235/45R17
Rear: 17x8, 4.5" backspacing, 255/45R17
The backspacing is critical on the rear or you will definitely get rubbing in the outer wheelwell lip.
'58 Delray 283 3-speed OD
In the family since new
Meyer
Reg: 11-01-19
01-27-21 10:50 AM - Post#2813088
    In response to Delray_58
So 8” all corners not possible?
Delray_58
Reg: 03-20-10
01-28-21 05:15 PM - Post#2813158
8" on the front might be possible, but it depends on ride height and the type of driving you do. With the 7" above on the front, with a 1" coil spring cut, I detect some rubbing during hard and tight cornering. However, at normal speeds this is not an issue.
There's some (expensive) trial and error involved here, at least for me. For example, my original rear wheels had a different offset that rubbed against the outer wheelwell, so I had to buy a new set with different backspacing and sell my initial pair of wheels. So, it can be painful. I'm sure that using one of those Tire and Wheel simulator tools will help you dial in the sizes correctly.
Execution time: 0.098 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:10 AM
