Username Post: 1964 ss        (Topic#364102)
basstracker
Reg: 11-09-18
01-23-21 12:18 PM - Post#2812755
is a gal of clear coat enough to clear my car. thanks
Site Ambassador
01-24-21 08:14 PM - Post#2812860
    In response to basstracker
If it’s straight clear and hasn’t been reduced yet it should be. But that depends on the amount of reducer that the manufacturer recommends because that determines the amount of sprayable material you end up with.
1957 Cameo Carrier
basstracker
Reg: 11-09-18
01-25-21 05:41 PM - Post#2812930
    In response to wagonman100
im thinking of spraying lc 4100 it mixes 4-1-1
Site Ambassador
01-25-21 06:48 PM - Post#2812938
So that should give you a gallon and a half of sprayable material. That should be enough depending on how many coats you wind up doing. Less than a gallon of clear (before hardener or reducer) was needed to do my ‘78 El Camino and that included a front air dam, front bumper, ground effects and rear roll pan in addition to the body.
1957 Cameo Carrier
basstracker
Reg: 11-09-18
01-26-21 05:33 PM - Post#2813022
I won't at least 3 coats, more if i've got the clear.
paintman
paintman
Loc: Smoky Mts., Tenn.
Reg: 02-27-12
01-28-21 07:25 PM - Post#2813168
If you are going to cut and buff, be careful wet sanding and buffing clear to a mirror finish will remove quite a bit.
Rich
1962 Chevy Impala Convertible 283 Auto
1964 Impala SS Coupe 327 250 Auto SOLD
2010 Mustang GT Convertible 5 speed
Execution time: 0.118 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:22 PM
