Username Post: 1965 Impala SS problem with the battery keeping charge        (Topic#364086)
Yruiz
Reg: 12-19-20
01-22-21 06:29 PM - Post#2812668
Hi I am wondering if any one know what can be the problem with my 65 the battery wont keep charge and I already changed the alternator. Does any one know what else could it be?
Gaspains
Gaspains
Loc: Mankato, MN
Reg: 11-23-09
01-22-21 09:34 PM - Post#2812676
    In response to Yruiz
In the old days, the console clock could drain a battery in short order. You may also have a glove box or trunk light staying on.
Kevin
1965 Impala SS Coupe
Regal Red with Black Interior
L74 327
M-20
3.31 Open, 12 bolt
65-66 FSCC #512
NIA #2832
Impalas4ever
Reg: 09-24-20
01-23-21 12:00 AM - Post#2812690
There are several things that can run down a battery. The alternator not charging, bad or dirty connections from or to the alternator or battery, bad battery, an excessive draw on the battery from some source. How old is the battery? Did you do a load test on the battery after fully charging it? Have you done a milliamp draw test on the vehicle to see if you have something draining the battery. Depending on the vehicle and any aftermarket accessories added, there is always a certain amount of draw from the battery for things like clocks, radio memory, alarm systems, etc. Changing out parts without knowing the issue can waste lots of money and time. So I would check that the connection are clean and tight, verify that the charging system is charging, load test the battery, and perform a milliamp draw test. One of those is going to tell you what the issue is. If you need help with those test, you should ask someone here and locally for help before you start spending more money.
Site Ambassador
01-23-21 07:34 AM - Post#2812719
    In response to Impalas4ever
Disconnect the positive battery cable and clip a test light to the cable terminal and touch it to the positive post. If it lights, you have a draw. The clock usually isn’t enough of a draw to make the test light light up. If you have a draw, start pulling fuses. When the light goes out you will know which circuit it is on and can check all of the components on that circuit. If the light doesn’t light you will have to move on to a milliamp test to check for smaller draws. If your battery is charged and passes a load test it shouldn’t die that quickly from a small draw.
1957 Cameo Carrier
"17th Year" Platinum Supporting Member & Senior Moderator
02-07-21 11:51 AM - Post#2813801
    In response to wagonman100
The clock won’t drain the battery until the points in the clock close and the solenoid winds the clock movement. In my case, the points fused together and burned the coil. You’ll smell the smoke when that happens.
59fins
Member #212 "20th Year" Gold Supporting Member
59fins
Loc: Surprise Az USA
Reg: 04-07-00
02-12-21 06:20 PM - Post#2814184
Bill H.
67 SS
Execution time: 0.112 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:40 PM
