Motown_mtrhd
Loc: Grand Blanc Mich
Reg: 12-22-15
01-21-21 04:46 PM - Post#2812573
Have any of you guys had problems realigning the gap of the hood to front fender? If you look at the assembly manual it calls out a specific measurement at the back of the hood and front corners, but if you align to that, the front end corners of the nose panel end up with the same gap, and of all the 65's I've looked at, there is no gap on that panel. What am I missing here? The hood gaps are very tight at the front corners if I don't shim out that nose.
Steve, 65 SS numbers 396,TH400 A/C Lots of power options. 1970 Chevelle, LS-LQ9 Tremec 5 spd,nuthin stock left. Drop Top . 34 Chevy 350 TPI,38 Chevy coupe. |
Edited by Motown_mtrhd on 01-21-21 04:47 PM. Reason for edit: No reason given.
docjns1
Loc: upstate NY
Reg: 11-12-19
01-21-21 05:01 PM - Post#2812577
In response to Motown_mtrhd
Are you talking the hood side to fender gap or across the front of hood to the header panel?
Steve
327 / 300 L74
M11 3 on the tree
12 bolt 3.31 open dif |
Motown_mtrhd
Reg: 12-22-15
01-21-21 05:24 PM - Post#2812579
In response to docjns1
Both, the manual calls for 58.17 inches at the back and front , width. If I square to that the front nose panel wont fit flush at he corners??
Motown_mtrhd
Reg: 12-22-15
01-21-21 05:36 PM - Post#2812580
Sorry I should specify, the gap at the front edge of the hood to nose panel can be adjusted by the hood to hinge mounting bolts. It's the gap on the hood sides at the front corners.. almost as if the header panel is not made wide enough to be square?
docjns1
Loc: upstate NY
Reg: 11-12-19
01-21-21 06:28 PM - Post#2812584
Sorry, can't help much there. Without measuring I have about 1/8-5/32' gap all the way including front and rear corners of hood to fender, and header fits snug to fenders, obviously a bit wider than the hood. Possible if you're using aftermarket repro tin its not quite to specs?
Steve
327 / 300 L74
M11 3 on the tree
Motown_mtrhd
Reg: 12-22-15
01-23-21 08:34 AM - Post#2812729
Thanks, yes I have only about that 1/8" gap too, seems a bit tight for dropping a 80# hood.
