hugo406
Reg: 11-15-11
01-18-21 02:34 PM - Post#2812347
Is the bracket that the hood latch and top grill is attached to the same on both the 1953 and 1954 Chevy car.8!897’u
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
01-18-21 04:43 PM - Post#2812358
In response to hugo406
Are you referring to part "O" in the image? If so, same part number for either year. 3701630 Part "N" however has different part numbers: 1953 = 3701635, 1954 = 3707844.
1951 Fleetline Preservation
'50 Styleline DeLuxe 4 DOOR SEDAN (Mist Green) |
kool53
Loc: Mukwonago, WI
Reg: 06-18-04
01-18-21 05:41 PM - Post#2812365
In response to RAM_51
Ram_51,
Is there a diagram or something that shows the back side of the grille? Wondering if the center tooth has a bracket on the back side of the center bar like the two outer teeth do.
Sorry - didn't mean to hijack the OP's thread...
RAM_51
Reg: 12-28-02
01-18-21 08:11 PM - Post#2812371
In response to kool53
I did a little research as the scan I posted initially from the 1955 Chevrolet Dial-A-Part Collision Estimator did not answer that question. First I had to obtain the group number for the bracket[s] (or, as Chevrolet calls them, retainers) in question. The illustration below shows them...but it only provided the part number and only showed two. I had to go to another publication to get the Group Number. With that number obtained from the 1953 Ready Reference manual, I was able to look it up in the Master Parts Catalog. For 1953, The Master Parts Catalog show that 2 are required. So from that, I would assume there is not one at the center vertical moulding. Thanks for keeping my brain sharp working the manuals.
