 Page 2 of 2 <12
Username Post: driving home tonight and loud counk and now car shaking bad        (Topic#363961)
Adam63impala
Adam63impala
Loc: From Memphis to Florida
Reg: 12-01-15
01-18-21 05:10 PM - Post#2812362
    In response to DonSSDD
well the thing is I am a lowrider . in September I installed air ride suspension and love it. so I will have to take my drive shaft to a shop and have them press on a new carrier bearing and will they also have to rebalance the drive shaft ?
DonSSDD
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
01-19-21 04:07 AM - Post#2812384
    In response to Adam63impala
If you only change the center bearing, no need to rebalance. Ask how much it costs to check the balance and do that if not expensive or if you have had any vibration issues in the past.
If you go to a slip yoke rear shaft, I’m not familiar with them, they are likely already well balanced I’d guess.
Member #2194
Edited by DonSSDD on 01-19-21 04:09 AM. Reason for edit: No reason given.
Adam63impala
Adam63impala
Reg: 12-01-15
01-19-21 07:38 AM - Post#2812395
thank you for this info!
Adam63impala
Adam63impala
Reg: 12-01-15
01-19-21 02:12 PM - Post#2812416
ordered a telescoping rear shaft with the poly carrier bearing . will I need to take it to a shop to have the carrier bearing pressed onto the front shaft
turbo38s10
turbo38s10
Loc: Agawam,MA
Reg: 09-17-09
01-20-21 05:42 AM - Post#2812461
You may as well replace the other u joint and balnace it at the same time. Better safe than sorry.
Adam63impala
Adam63impala
Reg: 12-01-15
01-20-21 07:53 AM - Post#2812466
    In response to turbo38s10
yeah I was figuring i might as well replace the other u joint as well.
Adam63impala
Adam63impala
Reg: 12-01-15
01-20-21 09:50 AM - Post#2812474
are the u joints all the same or do I need one specifically for the front one at the tranny ?
junky
Loc: Northeast CT
Reg: 06-27-10
01-21-21 05:17 AM - Post#2812517
All the same. If you are going to be doing them yourself, Rock Auto has the grease able AC Delco cross bearings / universals for a little over $7.00 each, plus shipping. There is a wide variety of brands available, and if you want the Rolls Royce of bearings, then buy Spicer Brand. About $20 + per bearing.
Adam63impala
Adam63impala
Reg: 12-01-15
01-21-21 07:34 AM - Post#2812526
    In response to junky
okay cool . yeah I've seen that brand and also moog. I ordered the telescoping drive shift from inland empire which comes with 2 u joints installed . not sure the brand they use but I'm certain its quality .
Adam63impala
Adam63impala
Reg: 12-01-15
01-25-21 09:08 AM - Post#2812886
is it necessary to put on 4 jackstands to remove the drive shaft?
del.impala
Loc: delaware
Reg: 04-13-11
01-25-21 09:26 AM - Post#2812887
Chock and block the front wheels and jack the rear up high enough for jackstands under rear of frame to remove the driveshaft.
Adam63impala
Adam63impala
Reg: 12-01-15
01-25-21 10:10 AM - Post#2812889
    In response to del.impala
okay cool. and I know to put wheels on ground before tightening the carrier bearing bolts . does it have to be at ride height for this or just simply wheels on ground? I have air ride .
Adam63impala
Adam63impala
Reg: 12-01-15
01-25-21 12:58 PM - Post#2812899
do I need to Jack it up to where the back wheels are off the ground?
del.impala
Loc: delaware
Reg: 04-13-11
01-25-21 02:19 PM - Post#2812904
However tall you can get the driveshaft out. Don't know your garage or driveway situation.
 Page 2 of 2 <12
Execution time: 0.088 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:46 PM
