Adam63impala
Loc: From Memphis to Florida
Reg: 12-01-15
01-12-21 04:44 PM - Post#2811946
was driving home tonight, car seemed to be shaking a little more than normal . went to grocery store . pulled out and as I go to accelerate I hear a loud clunk sound and my car starts shaking very bad . I couldn't even go above 15 or the shaking was very bad . any ideas ? checked the tranny fluid and it appears full .
69_BOWTIE
Loc: WYOMING,USA
Reg: 02-27-02
01-12-21 04:50 PM - Post#2811947
In response to Adam63impala
Center carrier bearing does it do it only while moving??
2001 Silverado 4X4
2005 FXDWGI
69 CHEVY Short Step
63 IMPALA 2/DR HRDTOP 327 |
turbo38s10
Loc: Agawam,MA
Reg: 09-17-09
01-12-21 04:54 PM - Post#2811948
In response to 69_BOWTIE
dito on the driveshaft.
Adam63impala
Reg: 12-01-15
01-12-21 05:06 PM - Post#2811949
yes only while moving and vibrated worse the faster I went . I was only going about 15 mph bc it was so bad . would the air ride suspension have maybe caused this bearing to go bad ?
Adam63impala
Reg: 12-01-15
01-12-21 05:16 PM - Post#2811951
also, is it supposed to make a clunking sound every time I put it in drive or reverse ? bc its done that for as long as I can remember...
RambosRide
Reg: 10-01-20
01-12-21 06:50 PM - Post#2811965
Center carrier bearing or losing a u-joint...better crawl underneath and take a look!
Adam63impala
Reg: 12-01-15
01-12-21 07:15 PM - Post#2811967
In response to RambosRide
should I get a slip joint drive shaft since running air ride and riding low ?
01-12-21 10:16 PM - Post#2811981
Check your fan first. Old fans do break and send a fan blade flying. The resulting vibration is hard to believe. Been there, had that happen.
Nitroholic
Loc: Out West In SoCal
Reg: 05-08-03
01-13-21 09:00 AM - Post#2811999
The worn out u-joint or bearing that you have been listening to go clunk ever time you put the car in gear for as long as you can remember has probably now given up the ghost entirely.
Remove the driveshaft and renew all of the consumable parts.
'66 C-10 Short Fleetside Big Window
Edited by Nitroholic on 01-13-21 09:04 AM. Reason for edit: No reason given.
japete92
Loc: No. Virginia
Reg: 01-18-13
01-13-21 09:09 AM - Post#2812002
A few suggestions prior to 'guessing' and throwing money at the problem:
Look under the car for obvious problems.
Sitting still, in neutral; rev the engine. Hear your noise? If so, the problem is NOT in the drive train, nor the suspension.
When driving and making the 'noise', does putting the car in neutral (and coasting) make it stop? If so, it's likely in the drive train; not suspension.
Allow the car to roll down a hill (in neutral, engine running or not) and get up to the speed the 'noise' typically appears. Hear 'noise'? If yes, it's not torque related, it's speed related (suspension).
Another 'test' for 'speed' vs 'torque' causation; as the car is allowed to coast 'faster', does the 'noise' increase in frequency? If so, suspension needs a thorough inspection.
The proper drive train angles, and how to measure them, are in the 61 Shop Manual. Check 'should be' vs what you have. If you are significantly 'off', you are putting more stress on the drive train parts.
All 'free' inspections/tests.
In summary, find the problem THEN correct it.
Pete
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
01-13-21 12:44 PM - Post#2812017
In response to japete92
While coasting in neutral with engine running or not, the driveshaft is turning and if it’s a bad center bearing, it will likely be banging.
Member #2194
japete92
Loc: No. Virginia
Reg: 01-18-13
01-13-21 01:23 PM - Post#2812019
In response to DonSSDD
You're right. The rear gears will rotate it as the wheels rotate. I know that. My bad.
Pete
USCGMK1
Loc: Vicksburg, Mississippi
Reg: 07-24-15
01-13-21 02:30 PM - Post#2812020
I’d check carrier bearing and U-Joint. I’d get the HD carrier bearing and slip yoke.
ragtp66
Reg: 12-09-07
01-13-21 07:39 PM - Post#2812032
Yes and YES best deal will be from show-cars.com You can buy just the rear half with slip yoke and the billet/poly carrier bearing
Toys:
1987 Sea Ray Pachanga 22
2007 Trailblazer SS -gone and missed |
Adam63impala
Reg: 12-01-15
01-14-21 07:43 AM - Post#2812051
In response to ragtp66
okay cool thank you . I'm headed to work and will have to check them out tonight . unless you don't mind telling how much they charge for that and if they are in stock? I hope this is an easy job for me to do in my garage
