Username Post: New Cam Cleaning        (Topic#363958)
DucatiRod
Loc: Maine
Reg: 12-31-20
01-12-21 03:00 PM - Post#2811936
I see Crane Cams wants you to use mineral spirits to clean their cams prior to installation. How about Brake Clean, which is what I already did, before I read! Do I need to start over, or what is the general consensus ?? I did use the Molly Lube supplied~
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
01-12-21 04:10 PM - Post#2811942
    In response to DucatiRod
the reason you clean the cam before covering it with the moly lube is the waxy shipping protective coating must be removed prior to the moly application so the moly can soak into the metal micro surface to protect the cams wear surface, and to remove any micro trash that might be stuck to that protective waxy shipping protective coating that was used to prevent rust in storage.(that protective waxy anti rust coating is not an ideal lubricant')
Edited by grumpyvette on 01-12-21 04:23 PM. Reason for edit: No reason given.
DucatiRod
Loc: Maine
Reg: 12-31-20
01-12-21 05:08 PM - Post#2811950
    In response to grumpyvette
So the idea its more just to get it good and clean, more than what you use. My concern was that they were saying "what to use" & I had used something else. I never lost a cam in the past, and always used whatever I had around (kerosene, carb cleaner, etc.)!
busterrm
busterrm
Loc: Wichita Falls, Tx
Reg: 08-30-10
01-12-21 11:20 PM - Post#2811983
Your okay I use that too. Just make sure that it squeaky clean when you lube it before it goes in the block. Lube flat surface of the lifter that rests on the cam lobe!
==== BOB ====
If I can't smoke the tires I want more!
1976 Chevy Nova
2017 Harley Davidson XL1200 Sportster
2018 Nissan Versa Note
51 AD 3100
Loc: Grant, AL
Reg: 08-30-20
01-13-21 02:55 AM - Post#2811988
same concept as buying a new gun. first thing you do is clean it. cosmolene is good for moisture barrier but not for use.
hey grumpyvette, while you're on the subject of assembly. whats your choice of assembly lube, assembly thread sealant , gasket cement/sealer ,and the like...lets say its engine assembly today...whats on your build bench?
and how about break-in oil?
Life's more fun, in a '51
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
01-13-21 06:58 AM - Post#2811991
    In response to 51 AD 3100
a few links and sub links to really help get you started off correctly
DucatiRod
Loc: Maine
Reg: 12-31-20
01-13-21 09:09 AM - Post#2812000
I tried to run the above links & Grumpy's site says I have an account, however I forgot my password & the password reset doesn't seem to send the email so I can get it fixed - I did it twice~
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
01-13-21 09:58 AM - Post#2812008
you have mail personal message
Edited by grumpyvette on 01-13-21 09:58 AM. Reason for edit: No reason given.
51 AD 3100
Loc: Grant, AL
Reg: 08-30-20
01-14-21 02:49 AM - Post#2812040
i appreciate it but it says i need to be logged in . so , i cant see anything.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
01-14-21 08:49 AM - Post#2812055
register and log on,
its free and its always a good idea,
to have multiple web sites to use as reference
Execution time: 0.063 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:42 AM
