Username Post: Help purchased 48 fleetline has tittle and current plates but no vin plate        (Topic#363945)
Tech420
Reg: 01-11-21
01-11-21 09:37 AM - Post#2811846
New to chevy talk recently purchased 48 fleetline has title current license plate but no vin plate inside. Only numbers found are on aftermarket stainless steel fire wall has a Briggs mfg co Detroit Michigan body tag that’s screwed on with Phillip heads the numbers on that plate match tittle. Is this a problem? Looked everywhere can’t find other tags or numbers on car or frame any advice appreciated thanks
TAT_2
Site Ambassador - Member #26 - "19th Year" Silver Supporting Member
TAT_2
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
01-11-21 02:23 PM - Post#2811865
    In response to Tech420
YO !!!
BEST TO ASK HERE
https://www.chevytalk.org/fusionbb/showforum.php?f...
09 PONTIAC- VIBE
08 PONTIAC- G6
93 VETTE - 40TH ANIV- RUBY RED- LT1/6-SPD/RAG TOP
QUOTE FROM HELEN
Maxbigblock
Site Ambassador -
Maxbigblock
Loc: Stuart, Florida
Reg: 12-16-01
01-12-21 05:39 AM - Post#2811906
Welcome to ChevyTalk!
Max
I'm originally from the ONCE great city of Flint, Michigan. The birthplace of General Motors, where A C Spark Plug was formed and headquartered, where the first Corvettes were hand built, and where my 1955 Chevy was made.
01-12-21 03:17 PM - Post#2811937
Welcome to ChevyTalk. What state issued the title and what state are you registering the car? Googled Briggs nameplate and some things came up. Some states issue their own ID plates, depending on the circumstances.
29-41, 42-48, 49-54 Moderator
1946 Chevy 1/2 ton pickup, stock. Purchased 11/18/17. Sold 9/16/20
Humpback Panel
Humpback Panel
Loc: Vanderbilt Mi. Lake City ...
Reg: 12-10-08
01-14-21 04:50 AM - Post#2812042
Tech 420
If you are 100% SURE you did not buy a hot car you have several options
1) leave as is and re-title / tag in your name and have fun
2) find out what the location of the original plate was and
Have a new inverted tag made and install it . Many companies
provide this service.
3) go find a state policeman , pull him over and ask him if the
car is legal .... it’s kinda the. 420 thing to do and probably why
you missed the whole tag thing in the first place
Dan
Looking for any information on the Chevy One Ton Humpback Panel truck.... Anything would be helpfull
lofat46
lofat46
Loc: Bloomingdale, IL
Reg: 08-12-13
01-14-21 06:37 PM - Post#2812101
Back when your car was new, many states used the engine serial number for title/registration purposes. The serial number plate should be screwed to the passenger A pillar between the hinges, closer to the bottom hinge. There should be a data plate riveted to the firewall that has nothing to do with vin/serial number. Go to www.chevy.oldcarmanualproject.com for more info. There are no “hidden” vin’s or serial numbers on the frame or body.
Edited by lofat46 on 01-14-21 06:40 PM. Reason for edit: No reason given.
Execution time: 0.169 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:23 AM
