Dwane
Reg: 01-09-21
01-09-21 10:02 PM - Post#2811750
Question for the guys that know Chevy frames...
My 73 Monte Carlo frame is somewhat pooched... looking at a 77 el Camino donor frame.. wheelbase of 116” is the same but f/r track width is slightly different Monte is 61.9”/61.1” el Camino is 61.5?/60.7? Any issues?? Also are the body mounts going to be a problem?? Are they not both a body frames?
Edited by Dwane on 01-13-21 12:34 PM. Reason for edit: No reason given.
Site Ambassador
01-10-21 10:41 AM - Post#2811777
In response to Dwane
You have to be very careful with El Camino stuff. The El Camino is always kind of an oddball when it comes to components since they are based on the wagons but changed around for the 2 door configuration. It’s surprising that the track width is different. The front and rear section of the frame should be the same between Monte Carlo, Malibu and El Camino. You’d have to get frame specs to determine where the differences are. With that slight of a difference it could have been in the spindles and/or wheel offset.
1957 Cameo Carrier |
Dwane
Reg: 01-09-21
01-13-21 12:40 PM - Post#2812016
In response to wagonman100
Seems there are a lot of odd stuff for the second gen Monte Carlo... a body frame but also known as a g body.. the switch over frame year.. seems to be a lot of confusion as to the frame class.. a g body frame I believe is 2-4” shorter in wheelbase...
Site Ambassador
01-14-21 02:56 PM - Post#2812085
The A body got changed to G body in the early ‘80s (1982 to be exact) which would be the third generation Monte Carlo, which started in 1978. The A body designation started to get used for a front wheel drive platform in ‘82. The ‘78 Monte Carlo got a 108” wheelbase and 108.1 in ‘82 with the G body change. 8” shorter (and 7.9”) than the second gens.
