realroamer
Reg: 02-11-15
01-09-21 09:02 PM - Post#2811741
My 92 k2500 4x4 with a 5.7 l and 4L80E is overheating while sitting in gear. I rebuilt the transmission,after no heat in cab and cooked tranny. I flushed the heater core,changed the thermostat and water pump and have been burping it for a week,even on stands. It still keeps overheating in gear. No water in oil,I get heat in the cab again,I replaced the exhaust manifold gaskets last year,I can't see any leaks anywhere,the return hose from the heater core gets warm and the thermostat is opening and pushing coolant through. When it cools and I squeeze the top rad hose with the rad cap on,I can here a click from the bottom washer on the cap,anyone know if that indicates a faulty rad cap?
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
01-09-21 11:27 PM - Post#2811754
In response to realroamer
How old is the radiator?
Greg
‘01 Silverado 2500HD 8.1/Allison 1000 Xcab/LB
'00 Explorer XLT 4.0 SOHC V6 Auto
'95 K1500 Z71 EC Short Step 5.7L+0.040/NV3500 SOLD
"The only thing necessary for evil to triumph is for good men to do nothing" Sir Edmund Burke |
scrambldcj8
Loc: Belchertown, MA
Reg: 04-06-03
01-11-21 04:42 AM - Post#2811826
Regarding your question about the rad cap being faulty. Does the upper hose become pressurized? Still though, shouldn't overheat sitting (idling) in gear. You say coolant flows through the rad....how well does it flow through? Sounds like the rad needs replacing/professional flush if all else has checked out.
realroamer
Reg: 02-11-15
01-11-21 08:39 PM - Post#2811893
In response to CowboyTrukr
I had it 6yrs so I assume original in it.
realroamer
Reg: 02-11-15
01-11-21 08:40 PM - Post#2811894
In response to scrambldcj8
I swapped a new rad cap today and it still overheats.
realroamer
Reg: 02-11-15
01-11-21 08:44 PM - Post#2811895
I got a used waterpump and came with a fan,the pump is good,pully alright,no leaks or noise,but I'm wondering if the fans on these trucks can make it overheat and if it's worth just putting the old fan onto this waterpump?
realroamer
Reg: 02-11-15
01-11-21 08:48 PM - Post#2811896
I only flushed the heater core and refilled the coolant and burped it.
How can I tell if I can flush the rad or buy another one?
454cid
Loc: West Michigan
Reg: 02-18-12
01-12-21 01:20 AM - Post#2811900
Where did the pump come from? Are you sure it's a reverse rotation pump and fan?
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
01-12-21 04:44 AM - Post#2811903
It’s a bit difficult to tell, but the lower portion of the radiator will have scale buildup. You may be able to see it by looking inside the lower hose inlet with a bore scope.
@bowtie44s Jeff, do you happen to have those pics at the ready?
Greg
Edited by CowboyTrukr on 01-12-21 05:09 AM. Reason for edit: No reason given.
scrambldcj8
Reg: 04-06-03
01-12-21 12:34 PM - Post#2811928
In response to 454cid
Ah Hah! Was just thinking the same..
rockfangd
Loc: Utica ny
Reg: 04-13-10
01-12-21 03:40 PM - Post#2811941
I was as well. Bolts on the same but the rotation is reverse which will surely cause issues.
Have to be sure the pump matches perfectly before replacing. Did it seem to happen after replacement?
Old School GM fan FOREVER |
Edited by rockfangd on 01-13-21 04:52 PM. Reason for edit: No reason given.
realroamer
Reg: 02-11-15
01-12-21 05:24 PM - Post#2811952
I pulled it from an exact twin truck with 5.7 ,I'm fairly certain it's the same. I had the problem before I changed the pump. I don't want to be clueless though, how can I be able to test and see if it's a reverse flow?
realroamer
Reg: 02-11-15
01-12-21 05:34 PM - Post#2811953
I got desperate and got a bottle of the preston coolant system flush. I hear it's not good for gaskets and seals,but others say it's safe. I lost heat in the cab but the temp was cool and I got enough heat to not fog the windows. The the 4L80E lost all drive,only gave me reverse....cooked,smoking fluid. I pulled it and the clutches were burned together, I replaced everything in the case and rebuilt it. Put it back it's all good now.I then flushed the heater core first,then ran it till I got heat in the cab but when it's in gear it gets close to the red line. I will try running the prestone for a day or 2 then throw a flush tee on the hose and water blast the system. I also replaced it with a new thermostat. I don't kow if I should fight finding bent fins if the flush does nothing or get a new radiator but I will be riding this job to the end,there has to be the fix.
rockfangd
Loc: Utica ny
Reg: 04-13-10
01-12-21 05:51 PM - Post#2811957
I could be wrong but it sounds like it was not bled properly.
It has to get up to operating temperature to open the thermostat to purge the air. I typically aid in squeezing the radiator hoses to expel the air.
When it gets close to red and you shut it down, is the coolant low after it cools?
Edited by rockfangd on 01-12-21 05:52 PM. Reason for edit: No reason given.
454cid
Loc: West Michigan
Reg: 02-18-12
01-13-21 01:50 AM - Post#2811987
That should be fine then. It's not actually reverse flow, its reverse rotation. The coolant flows in the same direction but requires spinning in the opposite direction. The change was made with the switch to serpentine belts instead of v-belts.
If the heater core return is plumbed to the radiator, don't use the Flush-T. It essentially only flushes the heater core that way, and not the block. You can flush the radiator with the garden hose in the upper radiator hose, and disconnect the lower hose, after you've run the chemical flush for however long you plan.
I'm not sure if small blocks have block drains.... you might look into that. That would be the best way to flush the block out.
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
01-13-21 11:47 AM - Post#2812014
Small blocks only have the freeze plugs. No specific block drain.
Greg
Site Ambassador
01-13-21 02:58 PM - Post#2812024
Small blocks do have a drain plug in the side of the block. It’s a small square headed bolt or on some vehicles there is a knock sensor there on one side. I usually remove them and put a petcock in there to be able to drain coolant low enough to not make a huge mess if I pull the heads. Luckily I’ve never had to use them.
1957 Cameo Carrier |
realroamer
Reg: 02-11-15
01-13-21 04:08 PM - Post#2812025
I ran the prestone flush through it until it burped up the air. The radiator heater cores must have been plugged from the bottom. I ran the prestone all day and it isn't overheating in gear or idol. I opened the drain plug on the radiator and kept the garden hose in the fill hole and ran the truck till it came clear,drained it all and filled it with antfreeze and even before I burped it again,it ran cool even in gear with all the air still in it. It is burping no problem now. It's running well,stays cool and gets heat inside the cab.
rockfangd
Loc: Utica ny
Reg: 04-13-10
01-13-21 04:54 PM - Post#2812026
So it is good now?
realroamer
Reg: 02-11-15
01-13-21 09:45 PM - Post#2812037
In response to rockfangd
Seems to be all good. I ran it most of the day got the air out,the rad is staying topped. No overheating driving in the driveway. I will take it for a drive tomorrow and test out my transmission rebuild and see if it shifts right and and won't overheat. Next Job Tranny cooler install I just need to make sure the system runs normal before I run the cooler off the radiator,but not sure if it's better to run the tranny cooler by itself.
65_Impala
Reg: 12-29-02
01-14-21 08:13 AM - Post#2812053
Yes, it is.
rockfangd
Loc: Utica ny
Reg: 04-13-10
01-14-21 07:01 PM - Post#2812103
In response to 65_Impala
That is good. So just air.
The cooler in the radiator serves 2 purposes, It warms the fluid and keeps it maintained at coolant temp.
It is good to have the fluid warmed faster with the coolant as it is less wear, and better performance.
1983G20Van
Loc: Bedford, Texas, USA
Reg: 11-13-02
01-16-21 08:00 PM - Post#2812233
Yes, it is.
Not in my experience!
When you are really working the converter and trans the fluid exiting the converter can get into the 250-300°F range. The coolant in the cold side of the radiator is substantially cooler than the engine temp and sometimes more than 100°F cooler than the trans temp. Fluid to fluid cooling will remove drastically more heat than fluid to air cooling especially if there are two coolers rather than one.
Best cooling results from plumbing the fluid from the trans outlet to the radiator, then from the radiator into the auxiliary cooler then from the auxiliary cooler back to the trans. My Express van came from the factory with this setup. Kept the plumbing factory just added a larger Trucool auxiliary cooler with the same design. Trans has not gotten over 160°F since. I tow a travel trailer with a 2,800 stall and a 383 making close to 500 hp, so not exactly taking it easy on the 4L85E.
1983 G20 Van, 350 TPI, Ported 906 Vortecs, Edelbrock 3817 Base, ASM oversize runners. Reed Custom Roller cam, 700r4, 12 bolt with 3.08 gears, Doug Thorley Tri-Y headers, true duals |
Edited by 1983G20Van on 01-16-21 08:03 PM. Reason for edit: No reason given.
