Username Post: 1-Wire Alternator Wiring Question        (Topic#363898)
Kevin Blank
Reg: 10-01-20
01-07-21 05:34 AM - Post#2811564
I have a stock 3-Wire 10SI 63-amp Alternator in my 1980 Camaro. 1-wire goes to my car battery, 2-wire connector is part of engine harness. I need to upgrade to a 100-amp output for electric fans, electric water pump, and electric fuel pump. I want to stay with 10SI case, so it fits my existing mounting brackets. I look on Jegs and Summit and notice their high output 10SI alternators are 1-wire. The 1-wire apparently connects to my car battery. Can I use these 1-wire alternators and not connector anything to my existing 2-wire connector? I think 1 of the 2-wire connections is for my idiot alternator dash light.
Thanks Kevin
SteveW
Loc: Shreveport
Reg: 04-24-02
01-09-21 12:44 AM - Post#2811687
    In response to Kevin Blank
I have been told one wire Alternators and volt meter don't use R-F or 1-2 .
I have also been told to use a volt gauge on ANY Alternator that exceed 65 Amps in output.
SteveW
Execution time: 0.238 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:54 AM
