Username Post: Heater Core Replacement        (Topic#363865)
Clive98
Loc: Clive Iowa
Reg: 07-21-12
01-05-21 06:14 AM - Post#2811394
1955 BelAir standard heater system, core leaking. Where can I buy a new "Standard"" heater core, or can you make minor adjustments to the "Deluxe" core to get it working?
The only new cores that I have found are for the Deluxe system not the standard.
57tim
57tim
Loc: Cameron, Wi, USA
Reg: 11-09-01
01-06-21 11:48 AM - Post#2811514
    In response to Clive98
Check with your local radiator shop. They should be able to help you with a new core.
57 Bel Air 2dr Ht
327 700r4
Madness
Reg: 01-25-09
01-18-21 10:47 AM - Post#2812328
    In response to 57tim
It's a little pricey, but it is for the standard heater. https://www.classicindustries.com/product/1956/che...
I see it says arriving soon, so that means China has not yet built it.
Edited by Madness on 01-18-21 10:51 AM. Reason for edit: No reason given.
Original57
Loc: Houston, TX
Reg: 04-07-09
01-20-21 06:52 PM - Post#2812509
local radiator shop custom made my heater core, using my original one as a example.
Rucco49
Reg: 07-25-19
03-08-21 03:13 PM - Post#2815789
    In response to Original57
Definitely try a local radiator shop first. Lucky for us to have a good one here.
Execution time: 0.073 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:56 AM
