Username Post: Big block gmc        (Topic#363793)
gfm64
Reg: 09-06-16
12-29-20 11:49 AM - Post#2810961
My grand son has a 72 GMC 1 ton dually. Some one some where dropped a big block of unknown size in it. Now he wants me to find out what it is. I'm guessing a 402 but I'm no expert. The number on the block above the water pump is cast in. number is 557752 3B any one know what that is?
dgstarr
dgstarr
Loc: Portland, OR
Reg: 04-16-13
12-29-20 04:47 PM - Post#2810977
    In response to gfm64
Believe it or not: 1977-1980 Oldsmobile 350 V8
Dave
Site Ambassador
01-02-21 09:26 AM - Post#2811190
    In response to dgstarr
Yes, that is the casting number for the Olds 350. The Olds valve covers do not look like Chevy ones and may make you think it is a big block. A picture of the engine would help or do a search for pictures of the Olds engine and see if it looks like the one in the truck and report back.
1957 Cameo Carrier
Member #51
01-02-21 09:44 AM - Post#2811193
    In response to wagonman100
Unless a person specifically knows the difference between a SB and BB Olds engine, it is nearly impossible to tell (unless you know your Olds casting numbers, or, what to look for).
Unlike Chevy SB and BB engines, Olds simply raised the block decks 1in. ALL, I mean, ALL Olds SB and BB valve covers, oil pans, brackets, accessories, exhaust manifolds, heads, pulleys, water pump, etc, etc, etc are a bolt on swap between SB and BB Olds engines.
OF COURSE, since Olds BB block decks are 1in taller, that means the BB intake manifolds are wider (and accessory belts are longer ------------------BUT THE BOLT PATTERNS ARE THE SAME AS SB MANIFOLDS.
In ultra simple terms, to replace a SB Olds (ie, 350) with a BB (ie, 455), you simply unbolt the exhaust manifolds from the heads, pull the 350, drop in the 455 and bolt the exhaust manifolds to the 455. NO, it's not exactly that simple ------------------------ but DAMN close.
The SB Olds are 260, 307, 330, 350, 403. The BB Olds are 400, 425, 455. And of course, internals are completely different. But on the outside, swapping a SB/BB Olds is TOOOOOOOOOOOOO EASY!
And yep, I've done it 2-3 times.
Oh ya, and Pontiac V8s are pretty much the same way.
Member #51
01-02-21 09:48 AM - Post#2811194
Attachment: 100_0977.jpg (78.2 KB) 10 View(s)
Attachment: 100_1021.jpg (91.93 KB) 7 View(s)
Attachment: 100_1175.jpg (72.79 KB) 7 View(s)
01-02-21 11:29 AM - Post#2811201
I have a buddy who has used the BPO 455 engines in several hot rods. He also has a '73 Buick Riveria with the 455. I've driven that Riv, and MAN ALIVE that thing burns up the road.
Member #51
01-02-21 11:53 AM - Post#2811203
The Olds 455 is a long stroke (stroke is bigger than bore!!!), long rod engine. They are not famous for top end rpm, but the low-mid torque is awesome. On the street, a well tuned W30 Olds will embarass an LS6 Chevelle. The 455 above that I built for the Cutlass is bored .060 and built to W30 specs. With the 3.27 1st gear in the Richmond 5sp and the 2.41 rear, it is a street killer and Interstate cruiser. The factory air cond is cold and still on R12. The cruise works just like it did when I bought it new. Very plain jane on the outside.
Attachment: DSCN1747.JPG (2.15 MB) 10 View(s)
Attachment: DSCN1795.JPG (2.15 MB) 8 View(s)
gfm64
Reg: 09-06-16
06-19-21 09:54 AM - Post#2821799
Well! the intake looks a lot larger than a 350 the distributor is on the back but from the pictures Ive seen you may be right.
gfm64
Reg: 09-06-16
06-19-21 09:56 AM - Post#2821800
Nice car . The engine matches yours even down to the exhaust manifold.
Execution time: 0.31 seconds.   Total Queries: 19   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:44 PM
