995jim
Loc: Ohio
Reg: 12-17-06
12-18-20 09:25 AM - Post#2810281
Hi, im looking for a site to buy a particular multiwire elect connector. To be specific its the plug connector that feeds a center console of a 65’ impala. ( connects the wire harnesses from dash to console together. )
Thanks jim
65' Impala SS, 65' Belair, 89' Silverado Z71, 95' Silverado Z71, 12' Silverado, 15' Silverado LTZ, 16' Tahoe LTZ |
65_Impala
Reg: 12-29-02
12-18-20 09:46 AM - Post#2810284
In response to 995jim
IS it a Pack-Con III terminal?
https://www.clipsandfasteners.com/GM-Pack-Con-III-...
I had a hard time finding pieces for that type. I ended up switching both sides of mine to use Packard 56 terminals and shells when I custom re-wired my car. For example, Clips and Fasteners has the terminals, but not the housing shells.
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
12-18-20 01:14 PM - Post#2810293
In response to 65_Impala
IF YOU CAN , YOU NEED BETTER TIRES AND YOUR SUSPENSION NEEDS MORE WORK!! |
995jim
Loc: Ohio
Reg: 12-17-06
12-18-20 04:20 PM - Post#2810301
https://photos.app.goo.gl/EX1oUdBywPRsGSyr8
If you open the link I have taken a pic of the connector I have. I think it may be what you have described. mabe you can verify,
thanks jim
Edited by 995jim on 12-18-20 04:26 PM. Reason for edit: No reason given.
12-18-20 04:40 PM - Post#2810302
That's a Packard 56, 8 wire male connector. Link to male connector.
Here's it's female mate. Link to mating connector.
995jim
Loc: Ohio
Reg: 12-17-06
12-19-20 11:01 AM - Post#2810353
In response to acardon
what crimping tool is used to assemble those connectors. I see a variety available at amer autowire
thanks jim
Site Ambassador
12-19-20 03:46 PM - Post#2810379
If you are going to do much wiring it is best to get a crimp tool with changeable jaws for a variety of connectors.
1957 Cameo Carrier |
65_Impala
Reg: 12-29-02
12-21-20 05:39 PM - Post#2810508
acardon has the connectors right. Those Packard 56 terminals are way easier to find the pieces for.
The MSD 3506 is supposed to be the correct jaws for the Packard terminals if you already have their plug wire crimper tool. If not, buy a cheap ratcheting crimp tool to put them in since most of those tools work the same.
If you get from AAW, then just ask. They'll help you out. I'm fairly certain the blue handled set is what you need though. Check the wire size range they give for the yellow vs blue.
Or something like this,
https://www.amazon.com/IWISS-Weather-Pack-Te rminal...
Might need to find a set for the heavier wires too though.
995jim
Loc: Ohio
Reg: 12-17-06
12-25-20 07:10 AM - Post#2810719
I actually do have a plug wire crimp plier, I just didnt put 2 and 2 together. It does have assorted dies,
thanks
