65acadian
Loc: Manitoba, Canada
Reg: 08-15-04
01-18-21 09:54 PM - Post#2812379
In response to Veryclere
Alright!! So... the starter saga may be over. Used a 40 grit flapper wheel and ground off 1/8 of an inch. 1/8” Allen key measurement is now very close. Also shortened the bolts so they wouldn’t bottom out. Removed the lock washers. Did not torque the bolts or use blue thread lock. Debating that still. Lastly, I got the bracket for the front of the starter to the block as well. 4 solid starts tonight so far.
So you had to take 1/8" off the starter nose mounting flange?
