Username Post: lowering front springs        (Topic#363590)
rod
Member #248 Senior Member
Loc: kingman,az
Reg: 04-29-00
12-09-20 06:54 PM - Post#2809712
has anyone bought lowering ft. springs. Ecklers has 2", Danchuck has 1 1/2. I want about a 2" drop.
I dont want to cut my original Nomad springs. but I do have a set [same orange stripe-weight rate] which I would cut. but dont know how much to cut.
thoughts
Thanks Rod in AZ
12-13-20 09:33 AM - Post#2809897
    In response to rod
know that lowering springs will affect your wheel alignment throughout the suspension travel. you may want to remove the springs to see exactly what will happen as you raise and lower the car.
Site Ambassador
12-13-20 07:12 PM - Post#2809927
    In response to bobb
You’d be better off with drop spindles. They lower the car by raising the wheel mounting location on the knuckle thus keeping the original suspension geometry and alignment specs.
1957 Cameo Carrier
498 chevy
"13th Year" Platinum Supporting Member
498 chevy
Loc: hayward ca.
Reg: 09-28-07
12-20-20 02:58 PM - Post#2810447
    In response to wagonman100
sound advice
Execution time: 0.108 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:18 AM
