 Page 4 of 4 « First<1234
Username Post: My 66 SS Automatic to Manual conversion        (Topic#363423)
brickwhite
brickwhite
Loc: Missouri
Reg: 09-05-19
09-16-21 08:07 AM - Post#2827190
    In response to brickwhite
Anyone??
Ted
space66
space66
Loc: Montreal,Qc
Reg: 06-01-16
09-16-21 08:45 PM - Post#2827240
maybe you just have a bad ground at the gauges, clock should always have power
My first car: 1970 Olds, 442,455 (1981-82)
My last car : 1966 Chev. Impala convertible,396 (1984-2020)
current car: Can't afford them anymore ...
brickwhite
brickwhite
Loc: Missouri
Reg: 09-05-19
09-17-21 04:54 AM - Post#2827247
    In response to space66
That was it, the ground off the Console harness was loose. Thank you!
Ted
Edited by brickwhite on 09-17-21 08:58 AM. Reason for edit: No reason given.
brickwhite
brickwhite
Loc: Missouri
Reg: 09-05-19
09-17-21 10:25 AM - Post#2827260
now to the oil pressure gauges connections...
Here is what was on the back of the gauge
If I used new copper 1/8" line I'll need one of these
I'd like to go to -4 AN connection an use a stainless braided line.. but looks like I'll need a lot of adapters.
Ted
Edited by brickwhite on 09-17-21 12:20 PM. Reason for edit: No reason given.
space66
space66
Loc: Montreal,Qc
Reg: 06-01-16
09-17-21 02:57 PM - Post#2827276
looks like you already have the AN adapter fitting for the gauge... , will you use the original light switch oil sender with it ?
here some Chevy Mechanical Oil Pressure Gauge Information > http://rmcavoy.freeshell.org/Oil_pressure_gauge.ht...
summit and others sell the Braided Stainless Steel, -3 AN or -4 AN line kits for the autometer gauges 1/8 NPT, you could check what kind of fitting it uses and comes with to fit your needs ...
-4 AN > https://www.summitracing.com/parts/atm-3228
-3 AN > https://www.summitracing.com/parts/atm-3235
> https://www.summitracing.com/parts/nex-16150
brickwhite
brickwhite
Loc: Missouri
Reg: 09-05-19
09-21-21 10:28 AM - Post#2827603
using the factory Oil Gauge in the cluster, not an after market.
Ted
Edited by brickwhite on 09-21-21 10:32 AM. Reason for edit: No reason given.
space66
space66
Loc: Montreal,Qc
Reg: 06-01-16
09-21-21 12:58 PM - Post#2827617
yes i understand, i never did it personally , always used copper, or nylon tube lines without issues , but i've seen guys using these braided line kits on original GM gauges, with a straight 5/16"-24 threads fitting at the gauge and it worked ... it's only few $ for the fitting, try it out to see if it works on your gauge.
or you could use the original compression sleeve nuts with a copper line inside the car from gauge and from fire wall adapt the connection to a braided one out in the engine bay ?
Execution time: 0.152 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:56 AM
