Username Post: heater box stil hot        (Topic#363378)
french-chevy
Loc: France
Reg: 11-22-20
11-22-20 10:05 AM - Post#2808333
hello everyone, this is my first post,i'm from France sorry for the spelling mistakes.i changed the heater valve on my impala 1962,i noticed heater box is stil hot inside the firewall even valve closed.its a problem in summer with the A/C cool pack.valve close corectly,i placed "H" connector on heater hoses too. should i put hand shut off on hoses?.how do you process folk living in desert state?. thank for answer. Christian
dcairns
dcairns
Loc: Orange CA
Reg: 11-07-03
11-22-20 02:55 PM - Post#2808355
    In response to french-chevy
This is a great question. I have factory AC and have wondered the same thing. On the factory AC, flaps in the ducting are supposed to keep the heat from the heater core form getting into the air stream, but I never thought the flaps were all that well sealed.
- Dave
1964 Impala 4-door sedan
Edited by dcairns on 11-22-20 07:41 PM. Reason for edit: No reason given.
pvs409
pvs409
Loc: Sergeant Bluff, Iowa
Reg: 01-10-05
11-22-20 05:24 PM - Post#2808362
62 Chevys with the heater valve mounted on top of the black painted firewall duct under the hood are famous for not shutting off even though they appear to be shut off.
Try readjusting the cable after removing the cable and pushing the arm on top of the valve to make sure it’s off.
I have had to disconnect the heater in the summer since the valve would not shut off completely.
If you still get heat, the valve may need to be replaced ( try the check on adjustment I suggested).
Paul
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
http://paulstensland.com
french-chevy
Loc: France
Reg: 11-22-20
11-23-20 11:45 AM - Post#2808419
    In response to pvs409
hello Paul,i changed the valve with a new and yes the lever is full close position. are there some impala 1962's owner experience to share about this exessive temperature?. this weekend i'll check the valve. thank for information. Christian
55Brodie
55Brodie
Loc: Little River, SC
Reg: 12-26-15
11-23-20 12:23 PM - Post#2808421
My 62's valve was missing so I replaced it with a new reproduction valve and H pipe. Adjusted it several times but it still allowed hot water to circulate. Like most reproduction stuff from China, it too is junk. I added a small manual shut-off needle valve in one of the heater hoses. Problem solved.
Verne_Frantz
Member #574 "61-64 Subject Matter Expert"
Verne_Frantz
Loc: Hightstown,NJ USA
Reg: 08-22-00
11-23-20 07:51 PM - Post#2808466
If the lever is all the way closed (against the tube) and it's still passing hot water, the problem is internal which means the valve needs to be replaced. There's no way to fix it.
Verne
YOUNG57
Loc: Tennessee
Reg: 12-06-10
11-24-20 10:25 AM - Post#2808511
    In response to 55Brodie
On one of my late model vehicles that has constant recirculating engine coolant thru the heater core the passenger side floor area would be hot from radiant heat from the heater core.
I spliced in a ½” ball valve in the heater hose between the engine and heater. I got it and two ½” hose barbs and hose clamps from a local big-box home-repair store.
In summer I close the valve to cool off the passenger side floor area and help the efficiency of the AC.
french-chevy
Loc: France
Reg: 11-22-20
11-24-20 11:50 AM - Post#2808522
    In response to YOUNG57
hello, right.. all theses repro valves are built at same place and obviously have same sealing problem. even if its not from factory the only way to fixe is hand shut off valve. it seems no post about it before.
Execution time: 1.303 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:24 AM
