Username Post: air/idle screws        (Topic#363370)
Aquavit750
Reg: 11-28-17
11-21-20 08:54 PM - Post#2808294
I rebuilt the carb got it on the street and it ran like a champ till I got off the freeway and came to a stop. I had to keep my foot on the gas to keep from stalling. Got back home tinkered with float, timing. air/idle mixture. none of it worked and manifold vac never rose above 13 psi or so. When turning screws for air/idle the passenger side gave me zero change whether I seated it or took it out all the way. The drivers side screw I could stall the engine with adjustments. Any ideas on why one side would have no effect on the performance? 66 impala, 283, Rochester 2gv
J-Dub
Edited by Aquavit750 on 11-21-20 08:55 PM. Reason for edit: No reason given.
Original58
Original58
Loc: Manitoba, Canada
Reg: 10-30-13
11-22-20 03:43 AM - Post#2808305
    In response to Aquavit750
Probably dirt in the passages.
You could also check the throttle plates as the transfer slots may be uncovered a bit too much.
Jeff
1958 Biscayne 283 Turbo-Glide 31,000 mi (now 35,000 and counting) driven daily
1966 Mustang Inline 6- C4 57,000 mi and growing daily
1929 Graham - Paige 612- the eternal headache that I will never sell
Execution time: 0.16 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:21 AM
