Username Post: 1962 Impala door hinge sagging, tips for rebuilding?        (Topic#363364)
62stlragtop
Loc: Portland Oregon
Reg: 04-16-07
11-21-20 12:10 PM - Post#2808265
Hey guys, my passenger door hinge is sagging and I am thinking about pulling the hinges out of the car one by one and rebuilding them with new pins/bushings. Is this a pretty straightforward project or is there something’s I should watch out for? I am planning on supporting the door carefully with a floor jack while pulling each hinge out one by one and rebuilding and then replacing. Has anyone done this before, and are there any tips you can give me that might help me with this process?
55Brodie
55Brodie
Loc: Little River, SC
Reg: 12-26-15
11-21-20 01:38 PM - Post#2808271
    In response to 62stlragtop
Chances are it is only the upper hinge that is worn. Unless you have access to a he-man hydraulic press I would recommend you replace the entire hinge with a Dynacorn unit. It ain't easy, but with assorted sockets, combination wrenches, ratcheting box wrenches and the right curse words, the hinge can be removed and installed without removing the fender.
pvs409
pvs409
Loc: Sergeant Bluff, Iowa
Reg: 01-10-05
11-21-20 02:41 PM - Post#2808277
I have had at least 5 to 7 original GM used sets of both door hinges rebuilt with new rivets and bushings.
I would not use any reproduction door hinges. Too many possible problems with poorly made reproduction parts that need to fit so the doors adjust correctly. This from experience on over 10 frame off restorations, including others who used various reproduction parts that did not work.
Paul
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
http://paulstensland.com
RambosRide
RambosRide
Reg: 10-01-20
11-21-20 03:28 PM - Post#2808278
The bottom of the door edge is tough to get a solid footing on jack pad I'd buy this or make something similar out of wood to cradle the door ...
https://www.eastwood.com/e-z-rest-door-hanger.html
The only gotcha in replacing pins and bushings is if the holes in the hinge pocket get oblonged from the bushing wearing out.
It takes a special tool to be able to weld them up and re-drill them straight.
Otherwise a air chisel and a flat end bit is what i use to drive the pin out and new one back in.
55Brodie
55Brodie
Reg: 12-26-15
11-22-20 01:15 AM - Post#2808299
    In response to pvs409
Paul,
The Dynacorn hinge form, fit and function is excellent.
62stlragtop
Reg: 04-16-07
12-04-20 02:35 PM - Post#2809361
    In response to RambosRide
Sorry for the late response. I was hoping I could remove the top hinge while supporting the door, then rebuild it and remount it while the lower one is still attached. That way the door would not have to come off the car entirely, also would it make lining up easier?
Execution time: 0.189 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:17 AM
