Username Post: quadrajet eletric choke adjust        (Topic#363359)
Mad Professor
Reg: 12-30-08
11-21-20 08:19 AM - Post#2808234
85 C10 305 H motor.
Choke had stopped working, I wired it open for a while. Elec choke was bad and it's connector too.
Reading up on things I discovered 2nd vac pull off bad too (problems with secondaries opening). I just got all those replaced with OEM GM parts. Soldered in new connector. Elec choke was riveted in, had to go to hardware store for self-tapping #10 screws.....
Question is best way to adjust the elec choke? I've got it set now so choke is barely open cold, and it opens fully after a short while.
It still started kind of hard, had to turn it over a bit and pump the gas. Had been sitting a few days. Will try it again today. I did depress gas pedal and choke was closed......
I'm in New England so cold winters. Should I turn it just a bit so choke is full closed cold?
62 Willys wagon
67 CJ5 Buick V6 w/OD
85 C10 305, SM465
89 S10 baja package
Edited by Mad Professor on 11-21-20 08:24 AM. Reason for edit: No reason given.
11-21-20 10:01 AM - Post#2808248
    In response to Mad Professor
Yes, because as you crank it the vacuum will open it a little, thus reducing the effectiveness for a cold start.
YOUNG57
Loc: Tennessee
Reg: 12-06-10
11-22-20 07:26 PM - Post#2808369
I think it is supposed to have about 1/4" gap between the top edge of choke buttterfly and airhorn when cold (ambient temp).
Mad Professor
Reg: 12-30-08
11-23-20 01:00 PM - Post#2808422
    In response to YOUNG57
That's where it is now, just barely opened.
Seems to start O.K. if not sitting a few days. It has a new fuel filter in it with the check valve so not sure why carb would be dry after sitting.
The old filter the valve stuck closed and truck would not start. Probably due to the crap E10 gas
It also doesn't seem to hold a high idle when cold. I have to fuss with the throttle until it warms up a bit. I need to look into that. If anyone has suggestions on that let me know.
Good things are 4bbl opens up now and when warm the choke opens fully. Choke was staying full shut and choked out the motor.
I'll see how it goes as weather gets colder, might adjust to full closed when cold.
Thanks for replies.
62 Willys wagon
85 C10 305, SM465
89 S10 baja package
11-24-20 04:18 AM - Post#2808475
Clean the throttle linkages. I clean mine with WD40 once a month. The engine must be cold. I don't know if lithium grease on the outer rods would hold up to heat and cold. I adjust the choke on mine twice a year. Once for cold weather. Another for hot weather.
'08 GMC Acadia 3.6L SLE
Execution time: 0.161 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:16 AM
