Username Post: vent visor glue        (Topic#363350)
bikernut
Loc: NEW HAMPSHIRE
Reg: 02-04-03
11-20-20 04:57 PM - Post#2808184
I have vent visors on my truck that are the glued on type and I had to replace the door, how do I remove the old adhesive from the plastic vent so I can reinstall with new 3M tape
3500 Dually Member # 252 and Damn proud of it
2020 GMC Acadia Denali
1992 Chevy S-10 4X4 Blazer
2015 Harley FLHTCUTG
2003 GMC 3500 Dump
87 Pontiac Trans AM GTA
Site Ambassador
11-21-20 10:39 AM - Post#2808252
    In response to bikernut
I usually use a flexible putty knife. It works very well for removal. I then use a razor blade to remove the old double faced tape. It is difficult to get it all the way off, but since I do bodywork for a living I get a lot of practice. If you can get an edge of the tape loose, stretching it makes it release from the surface. Works about 50% of the time. Be careful working with them off the vehicle. They get brittle over the years. I once got one off, cleaned, retaped it and it cracked trying to put it back on. Don’t worry if the razor blade scratches the surface too much, the new tape will hide those, even from the front side.
1957 Cameo Carrier
chevkarl
Reg: 10-01-13
01-11-21 01:09 AM - Post#2811822
A plastic scraper and wd40 should work also.
Senior Moderator
01-11-21 06:40 AM - Post#2811832
3M Stripe-Off wheel chucked into a regular drill will do it quickly without risk of any scratches. It may seem a little expensive at first but they last a long time, and you'll find other uses for it over the years.
Site Ambassador
01-11-21 07:06 PM - Post#2811885
    In response to someotherguy
Don’t use the stripe wheels on the plastic visor, only on the metal body of the vehicle.
1957 Cameo Carrier
Senior Moderator
01-13-21 07:55 AM - Post#2811994
    In response to wagonman100
Good point. I only assumed (possibly incorrectly) that he was looking to get the tape off the vehicle itself.
Site Ambassador
01-13-21 02:41 PM - Post#2812021
I knew what you meant Richard, I just wanted to make it clear that you meant only on the body.
1957 Cameo Carrier
Algoma56
Reg: 03-14-05
01-16-21 12:04 PM - Post#2812211
It never hurts to clarify instructions or guidance. Better safe than sorry.
Execution time: 0.156 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:04 PM
